Thread: GXP Running Srange at Higher Speeds
Results 1 to 2 of 2
  1. #1 GXP Running Srange at Higher Speeds
    Feb 2017
    IA
    Hey all,
    My '05 GXP has been having some issues at higher speeds, like 65-70. The RPMs seem to fluctuate between 1800-2000, almost like it's shifting from gear to gear. Also does it with the cruise set. Could this just be a sensor, or maybe something with the active fuel management?
  2. #2 Re: GXP Running Srange at Higher Speeds
    AFM/DoD shouldn't make it vary RPM that much, it's not suppose to change the RPM at all when it's working anyway. It's only dropping to 4 cylinders and nothing else.
    It could be TCC related, it's something you could watch on a scan tool to see what's really going on.
  1. cam and higher rockers
    By dbane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2014, 06:15 AM
  2. Losing boost at higher speeds
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2014, 05:59 PM
  3. Higher KR after LIM Change
    Last Post: 08-01-2013, 02:07 PM
  4. What gives the L36 Higher Compression?
    By BlackGT97 in forum General Tech Discussion
    Last Post: 04-10-2012, 09:52 PM
  5. Running higher grade fuel.
    By Dohner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-25-2008, 09:42 PM
