Thread: reducing burst knock
Results 1 to 13 of 13
  1. #1 reducing burst knock
    Kemmerer, Wyoming
    I've taken a few scans of my car and seem to have a bit of kr. I'm wondering if it is burst knock because I have cut timing a few times with no noticeable effect. One person suggested to 0 out the burst knock table because it isn't real knock. The only problem is that he can't remember what tables he adjusted and I don't see an LS4 specific guide on what tables to change and what to change them to. here is a screen shot of the knock retard page in my tune:
    https://drive.google.com/file/d/0B6K...ew?usp=sharing
  2. #2 Re: reducing burst knock
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    How's the lower motor mount or trans mount? I had random knock all over with my regal that couldn't be tuned out. Turns out it was a bad motor mount. Once I fixed it, no more kr
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: reducing burst knock
    Log Burst knock if you think it's what is happening.
    Base vs cylinder air delta is the main table. Cut it in half or more, or just remove it all.
  4. #4 Re: reducing burst knock
    Kemmerer, Wyoming
    will the burst knock retard show up as actual knock retard? I'll try logging it first and see what it shows.
    I haven't checked my motor mounts yet, but it could be worn
  5. #5 Re: reducing burst knock
    It will show up on both knock retard and burst knock if you log them. There should even be a type of knock retard you can log to see what the computer is saying I think.
  6. #6 Re: reducing burst knock
    Kemmerer, Wyoming
    I just cloned my knock retard graph and replaced the knock retard with burst knock.
  7. #7 Re: reducing burst knock
    What?
    Not sure what you are doing. I was just saying to log both knock retard and burst knock in the main channel display. See what it says when you take a log. Likely you'll end up just zeroing out the burst knock table so it's a non factor while tuning.
  8. #8 Re: reducing burst knock
    Kemmerer, Wyoming
    I understand
  9. #9 Re: reducing burst knock
    Kemmerer, Wyoming
    I added burst knock to my graph and chart, and only saw .1. I wonder if something is loose because I cut several degrees of timing and it didn't seem to affect the kr much.
  10. #10 Re: reducing burst knock
    Post the file and log in a drop box or something so they can be viewed.
    I don't think you can add attachments on this forum but you might be able to.
  11. #11 Re: reducing burst knock
    Kemmerer, Wyoming
    I'll start a thread on hp tuners forum
  12. #12 Re: reducing burst knock
    GT Level Member mguzzo's Avatar
    Buffalo NY
    what's the PID for logging burst knock?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  13. #13 Re: reducing burst knock
    Quote Originally Posted by mguzzo View Post
    It's only going to work if you own a LS type vehicle. Burst knock is not used on a 3800.
    It would just be labeled burst knock in the main channels list.
  1. 3.69's As a KR reducing mod?
    By Ace in forum General Tech Discussion
    Last Post: 09-07-2012, 07:41 AM
  2. Wot pop/burst at shift?
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 05-21-2012, 09:01 AM
  3. hose go burst?
    By JoeC9107 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2010, 02:24 PM
  4. still burst knock no matter what >_<
    By fst in forum PCM Tuning
    Last Post: 10-17-2008, 06:11 AM
  5. Next step for reducing KR?
    By the1euge in forum General Tech Discussion
    Last Post: 07-18-2008, 09:18 AM
