Thread: cylinder 1 misfire along with tick in supercharger
Results 1 to 5 of 5
  1. #1 cylinder 1 misfire along with tick in supercharger
    Jul 2015
    Please please please help me!! I miss driving my GTP!!
    I have a 2002 Grand Prix GTP, and I put a new head gasket set in it. After I got the motor put back together I cycled the key, and started the car. I let the car run to get all the air out of the lines and once everything was settled it ran fine. I test drove it with no problems, and then parked it for a few days. after the few days i drove give or take 12 miles and the car started to miss on cylinder 1, and i began to hear a tick. the tick is not constant. and when i have the car running every time it ticks the boost bypass actuator moves. when i discovered the car was having a miss i changed the plugs, wire, coil packs, ign. module, but its still missing on cylinder one. when the injector for cylinder 1 is plugged in it missed bad. when i unplug injector 1 it runs smoother and the tick stops. i swapped injectors with cylinder 3 and the miss is still on cylinder 1. could it be low compression, bent valve, injector connector, the wiring? i need help bad!
  2. #2 Re: cylinder 1 misfire along with tick in supercharger
    Feb 2013
    37.295091, -121.930053
    would need video of it making the noise to know for sure. it could be chiped piston or spun bearing or faulty plug, bad wire, vac leak, coil pack going etc.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: cylinder 1 misfire along with tick in supercharger
    Jul 2015
    i know for sure its not the plugs, wires, coil, ign. module. vacuum lines are good(brand new), my piston is not chipped i know for sure. its not a spun bearing. ill take a video and post it in a minute.
  4. #4 Re: cylinder 1 misfire along with tick in supercharger
    Feb 2013
    if it was low compression then your car would not fire properly and have lost of power and stumble in the rpm range.
  5. #5 Re: cylinder 1 misfire along with tick in supercharger
    Wouldnt hurt to check the valve springs/rocker arm.
  1. Cylinder #3 misfire
    By redgtp97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2013, 04:08 PM
  2. Cylinder #2 misfire
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:38 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder 3 Misfire
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 11:24 PM
