Thread: Missing under boost only
Results 1 to 20 of 20
  1. #1 Missing under boost only
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    98gtp 3.4 pulley zzp tune, thrasher air box no cat 3 down pipe just fixed my lean condition new supercharger gasket injector o rings fixed vacuum leaks now it's sputtering under boost
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #2 Re: Missing under boost only
    GXP Level Member
    Mar 2015
    Tomball
    How old are plugs and wires?
  3. #3 Re: Missing under boost only
    Topeka, ks
    Less than year autolite 104s plug wires replaced less grabbing year and icm number one plug wire end came off and the wire inside was toast replaced it tackin for drive now
  4. #4 Re: Missing under boost only
    Topeka, ks
    Took out the front three plugs cleaned then with a wire brush changed the number one plug wire now got random multiple misfire check engine light flashing at me any thoughts
  5. #5 Re: Missing under boost only
    Howell, NJ
    Did you pull the wire by the boot or the wire.
  6. #6 Re: Missing under boost only
    time for new plugs? and new wires. if you got the local parts store wires most have a warranty, will replace one time at least.
  7. #7 Re: Missing under boost only
    Topeka, ks
    I had a spare set of wires think I messed up a few ends I recrimped them gonna check the back three now, are autolite 104 ok I got some 103 and 606 I believe
  8. #8 Re: Missing under boost only
    Topeka, ks
    Ok last night car ran perfect woke up this morning let it warm up came out side after ten minutes it's missing out check engine light is on and flashing says cylinder 6 miss fire car seems to run pretty well only thing left to do is run a compression check on that cylinder n swap out cylinder 6 injector any thoughts??
  9. #9 Re: Missing under boost only
    Topeka, ks
    Guess it could be the icm also but I checked last night pulled wire of cylinder 6 coil pack and it was bright blue sparks popping.Can the icm fail intermittently?
  10. #10 Re: Missing under boost only
    icm can test good and be bad still, act up when they get hot.
    make sure the plug wires are not touching the o2 wires on the back side of the engine.
  11. #11 Re: Missing under boost only
    Topeka, ks
    It only misfired when it was cold light still on not flashing I'll check the wire position
  12. #12 Re: Missing under boost only
    Topeka, ks
    I do believe cylinder 6 is the only plug wire that I have zip tied to something metal on the backside of the motor maybe that's what it is
  13. #13 Re: Missing under boost only
    dont zip tie wires to metal. undo that, check the wire for damage. a grounded plug wire will misfire.
  14. #14 Re: Missing under boost only
    Topeka, ks
    Ok it wasn't zip tied it was in the spark plug holder on the rear close to the o2 sensor but not touching it was touching the o2 wiring so I repositioned that see what happens
  15. #15 Re: Missing under boost only
    that might fix it. seen posts where guys had issues when the plug wire touched o2 wires.
  16. #16 Re: Missing under boost only
    Topeka, ks
    I hope so this cylinder 6 issue has been on n off for couple weeks now
  17. #17 Re: Missing under boost only
    Topeka, ks
    Think it's fixed!! :-) check engine light went off on it's own right after I moved the o2 wiring hasn't came back car it's running better than it ever has in my option
  18. #18 Re: Missing under boost only
    that was it i'd think. now to wait for the next issue,,,there will be one sooner or later lol its a W body after all.
  19. #19 Re: Missing under boost only
    Topeka, ks
    Yup I'm used to it all I've ever owned just hate when it ends up being a wild goose chase thanks for the help!!
  20. #20 Re: Missing under boost only
    well you learned not to zip tie the plug wires to another wire harnesses..
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
