Thread: Struggling with my GTP
Results 21 to 40 of 57
  1. #21 Re: Struggling with my GTP
    Scott...I said to have him work the pintle aka moving part of the egr right there at the bottom. if it won't free up..snag one at the JY too.
    Personally.. the flow issue not being detected.. well it would be detected by the map. if the map is bad..you see the issue. Plus if the EGR pintle is stuck open that could be adding flow and masking flow.
    MAF, MAP and EGR are what I'd aim for.
  2. #22 Re: Struggling with my GTP
    Feb 2013
    37.295091, -121.930053
    Quote Originally Posted by ScottyDoggs View Post
    frank and beans!!!!!!!! he was masturbating with that cheese!!!!!!!!
    there fixed
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #23 Re: Struggling with my GTP
    dont think you ever saw something about mary......did ya?
    well, all we got to do is back up the train..............WE GOT A BLEEDER!!!!!!!!!
  4. #24 Re: Struggling with my GTP
    Feb 2013
    i tried to watch it but found it really dumb
  5. #25 Re: Struggling with my GTP
    yet so damn funny........but im a child at heart still lol
  6. #26 Re: Struggling with my GTP
    Sep 2015
    alabaster al
    http://s1175.photobucket.com/user/Ki...0Uploads/story
    I think I did it right. I took pictures of the maf and the cracked wire, the egr valve (I think), the tube that isn't connected, and the whole engine. And there's a mess of taped crap
  7. #27 Re: Struggling with my GTP
    Feb 2013
    here is a vacuum diagram this will help
  8. #28 Re: Struggling with my GTP
    good job eric, show him a 98 up diagram lol you got a 97 with a vac tree on the blower.
    this line goes to the other 1/2 under the fuse box, look for the other 1/2 there. you can use new vac line to repair it, just push the hard line into the new vac line.
    the rest looks ok.
    hers a 97 diagram.
  9. #29 Re: Struggling with my GTP
    Feb 2013
    Quote Originally Posted by killywilly98 View Post
    I have a 98 grand prix gtp.
    scotty go back and re-read
  10. #30 Re: Struggling with my GTP
    and i ask you look at the pics posted, thats a 97 blower all day long.
  11. #31 Re: Struggling with my GTP
    Feb 2013
    uhhh its still a gen 3 scott. and yes i know that 97 they DID use a different vac route vs 98 - 03
  12. #32 Re: Struggling with my GTP
    Sep 2015
    alabaster al
    Explain the extra line again? And yeah that diagram is underneath my hood
  13. #33 Re: Struggling with my GTP
    the busted line goes to a T like in this pic, or turns past the the bottom of the fuse box to the wire harness.
    changing the battery will bust the line time to time.
  14. #34 Re: Struggling with my GTP
    Sep 2015
    alabaster al
    what problems will that busted line cause? and how the MAF sensor look? the inside of the plug is like orange and the rubber is a little cracked.
    should i replace the MAF or replace the plug?
  15. #35 Re: Struggling with my GTP
    dint see a maf pic. you can take it out and clean it with maf cleaner. but if it was a low voltage code thats not gonna fix it.
    and that line is a open vac leak for one. 2, its what powers your hvac controls. like air flow direction, from floor to vent and defroster. that stuff is likely not working right.
  16. #36 Re: Struggling with my GTP
    Sep 2015
    alabaster al
    This whole time I've been thinking the MAP sensor on the supercharger was the MAF.
    The map sensor is the one with the dirty plug. I found the maf sensor and took it off and it's really clean, looks kinda new, the plug too. I tried running the car with it dis connected and it shut off as it has been a lot of the time. I blew on the maf plug and all that and hooked it back up and the car started just fine. Still idling rough, but it started. Is it the MAF or do I need to change the coil packs and spark plugs that are long overdue?
  17. #37 Re: Struggling with my GTP
    lets clear up each parts so we are all on the same page here.
    MAF is screwed into the top of the throttle body. only has a plug to it.
    map is on the firewall side of the engine near the alt and has a vac line and a plug to it.
    did you ever check that fuse?
  18. #38 Re: Struggling with my GTP
    Sep 2015
    alabaster al
    I swapped that fuse with a spare, but I don't really know how to test it. And yeah I looked it up and found it, I unscrewed it and all and it looked really clean. The plug into it is purple and looks newer than everything else. Would the low circuit power for the maf or whatever that code said have anything to do with the mess of wire?
  19. #39 Re: Struggling with my GTP
    low voltage code can be a bad maf, bad wires or a blown fuse.
    2 out of 3 look good, time for a maf. find a used one at the junk yard, or ebay, your part # is on top of the maf.
  20. #40 Re: Struggling with my GTP
    This is the 2nd or 3rd 98 that I have seen with the 97 blower stock. I am assuming that some of them went on to early 98s or they had some laying around still and threw them on.
  1. Bad knock and struggling...
    By Amb4 in forum Turbo
    Last Post: 11-24-2010, 10:12 PM
