Thread: Fuel Pump
Results 1 to 20 of 74
  1. #1 Re: Fuel Pump
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by rkm View Post
    I agree that the plugs need to be ruled out. I will. But if no one has any more suggestions, if the plugs check out, I suppose I am going to throw a fuel pump at it. Any more suggestions? This is an every day driver, not intended to raise hell in. Our 400 small block is reserved for that.
    If you want to rule out the fuel pump look at your O2 sensor and see if it is going lean. Also look at your MAP for vacuum and pressure. I had a situation when I came in this board where the car layed over and I ended up having a check valve in the line leading to the MAP sensor. I checked everything and chased my tail for over a month thinking it was everything from a bad fuel pump to a bad MAF and MAP sensors. I changed the sensors and bought a fuel pump assembly and ended up being a .25 cent T that I needed. I didn't have the Torque app at the time or anything like that. I used a fuel pressure setup and an oil pressure sending unit screwed in where the gauge went on the fuel pressure tester and connected the gauge inside the cabin and used it for a couple of days to see how my pressure was. All that was for nothing Bill ended up spotting the check valve and when I tried it again it was working again so it wasn't the filter I thought it was. I think what you will find is the plugs are bad, but you will be able to tell a lot by playing with the Torque app.
    Jeff
  2. #2 Re: Fuel Pump
    Sep 2015
    USA
    I pulled the plugs, they were showing their age for sure, but still in good shape and burning clean, real clean. Installed plugs were NGK R TR55 V-power, replaced with the same.
    Still did not fix the issue.
    What I learned. This setup was designed by an engineer who works(ed) for GM. The previous owner found and contacted him to custom design these mods with certain requirements in mind. Mainly, to walk that fine line between reliability and performance. And to eliminate the need for headers. Now, if I could find who this was.
  3. #3 Re: Fuel Pump
    Sep 2015
    USA
    Quote Originally Posted by J57ltr View Post
    Jeff
    Wouldn't you think it would be throwing codes if running lean? It has no codes. I even went as far as creating a situation to cause a code just to see if it was working. I caused a misfire and the check engine light came on immediately. Scanned it and as expected it gave me the code for misfire on cylinder 5, just as planned. As I have mentioned before, I do not think the fuel pump has totally gone bad, just weakening and just cant keep up with demand.
  1. 04/05 fuel pump install- Fuel pump access in trunk
    By chrsmi1 in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2015, 09:26 PM
  2. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  3. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  4. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
