Thread: Could use some suggestions.
Results 1 to 20 of 68
  1. #1 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by SgtMarshal View Post
    here is my opinion: I have an XP cam, ported heads, a full size intercooler and am running a 3.25" pulley. my car has kr when I go smaller. you will not be able to just buy one pulley and call it good, unless you are will to settle with a 3.5". you could probably run a 3.25" pulley if you did the headers 1.9 rockers and a methanol injection, but again tuning will be required.
    Wow you have a xp cam ported heads and fsic and your kr rises if you go lower? Injectors are the same? Or you upgraded? Im running 2.8 no knock with the same cam headers and a gen v with ported heads..can't understand that one
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Could use some suggestions.
    Kemmerer, Wyoming
    Quote Originally Posted by jayroca View Post
    I have no idea what's wrong with it. I haven't been able to find a vac leak. did have an exhaust leak that is fixed now. I'm on 42 lb injectors and a northstar tb/maf. I'm planning a swap to 130 lb springs in the next couple months, so we will see what difference that makes. doing a double roller timing chain and a bigger harmonic balancer in the next month.
  3. #3 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    Oh ok.. Not tryna tlk s**t just tryna figure why all those mods you have and its not allowing you to drop pulleys and you have every knock killer for the motor other then e85 ...
  4. #4 Re: Could use some suggestions.
    Kemmerer, Wyoming
    I understand. no offense taken. I am in the process of a custom turbo build, so I'm not real concerned about the big pulley.
  5. #5 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    What type of intercooler?
  1. Looking for cam suggestions...
    By transam24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2013, 11:44 PM
  2. 2 new DTC's, need some suggestions
    By 06camarodude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:10 PM
  3. n/a gp gt need some suggestions
    By kyleheine298 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 12:26 PM
  4. cam suggestions?
    By 2000gprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:39 PM
  5. ok any suggestions?
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-21-2009, 01:04 PM
