Thread: 20+lbs of boost!?
Results 1 to 7 of 7
  1. #1 20+lbs of boost!?
    SE Level Member kewGTP's Avatar
    Mar 2015
    Appleton, WI
    Took the car out for a quick scan before the headers/dp/rocker/pulley install and for the most part all looks good. . . except when I convert the kPa to psi it says I'm hitting anywhere from 15-20lbs of boost on an other wise stockish car. Am I reading this incorrect or should I be looking for a vacuum leak??
    https://drive.google.com/file/d/0B3y...ew?usp=sharing -HPTuners file
    https://drive.google.com/file/d/0B3y...ew?usp=sharing -Excel Format
    '05 GTP - E85 - XP Cam - 3.0 Pulley - Supporting Mods...
  2. #2 Re: 20+lbs of boost!?
    Mar 2015
    Appleton, WI
    Just thinking, if I remove 14.7 from those numbers than my boost levels would be correct. . . . Solved?
  3. #3 Re: 20+lbs of boost!?
    Dec 2013
    ohio
    Still sounds high for stock. Running 2.8 pulley and I'm getting !4 to 15#s.
  4. #4 Re: 20+lbs of boost!?
    How much KPA are you seeing?
    Like 145?
    I just take the number above 100 because 0-100 kpa is not in "boost" yet. So like 145, just take the 45 and thats 6.5ish psi.
  5. #5 Re: 20+lbs of boost!?
    Mar 2015
    Appleton, WI
    Like 145?
    Yep anywhere from 145-165 KPA when WOT, doing your math makes sense and puts my boost amount in normal spec for its current mods. Thanks sir!
  6. #6 Re: 20+lbs of boost!?
    Apr 2015
    Columbus, OH
    Top Swapped 01 Imp
  7. #7 Re: 20+lbs of boost!?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    you're reading manifold Absolute pressure (relative to zero pressure absolute, like deep space) not gage pressure (relative to ambient barometer). so you have to subtract the baro reading (i.e. the "normal" air pressure)
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
