Thread: L76 springs and VS cam compatibility?
Results 1 to 5 of 5
  1. #1 L76 springs and VS cam compatibility?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Can I run L76 springs with a VS cam? Or is the lift on the cam too high for the springs?
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  2. #2 Re: L76 springs and VS cam compatibility?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I run those springs, and they are great for a rocker setup but I personally wouldn't use them on a cam Setup.
    L76 springs have a max lift of .520", so technically you could run them as the VS cam has a lift of .512" but I still wouldn't. I would get some LS 90# springs or possibly even 105's to leave yourself some more headroom to shift at a higher RPM or if you ever wanted a bigger lift cam.
  3. #3 Re: L76 springs and VS cam compatibility?
    Ls90# at least
    04 Comp G.
  4. #4 Re: L76 springs and VS cam compatibility?
    Jul 2008
    Dekalb, IL
    From further reading I think I'm going with the L76 springs. Apparently the springs are underrated and Will from Overkill actually recommends using them with a small cam such as the VS cam. I'll be getting some Viton valve seals, probably some Felpro ones, and try to go with stock L76 valve spring retainers. I hope there is enough spring clearance with the LSx style retainers. If not I might have to get the modded ones from ZZP or the Manley ones from Intense.
  5. #5 Re: L76 springs and VS cam compatibility?
    GT Level Member mkyota1's Avatar
    Daytona, florida
    L76 springs are a 90# seat pressure ls style spring. They worked great in my build as well as many others. They are easy on the chain and damper too. I would rec replacing the chain and damper with new while they are out.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  1. Compatibility
    By whitegt956 in forum Introductions/Noob Questions
    Last Post: 08-25-2013, 12:39 PM
  2. (In)compatibility
    By Dr Cedric in forum Introductions/Noob Questions
    Last Post: 08-25-2013, 12:21 AM
  3. SE/GT Compatibility
    By ShadowSwept in forum General Tech Discussion
    Last Post: 03-31-2012, 12:55 PM
  4. MAF compatibility
    By benner in forum General Tech Discussion
    Last Post: 06-13-2010, 05:34 PM
  5. Compatibility
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2009, 02:34 PM
