Thread: Snapping studs?
Results 1 to 14 of 14
  1. #1 Snapping studs?
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    I bought the ZZP power log a few days ago and I was waiting to put it in while I read some write ups. After reading them, my question for you guys is what are my chances at snapping an exhaust stud? My car has 170k miles, and I live in the North East so things rust up here.
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: Snapping studs?
    chances are good. if you do break one you can drill it out and use a nut and bolt in its place.
  3. #3 Re: Snapping studs?
    Feb 2014
    Rhode Island
    Should I just bring it to my mechanic? That way if he breaks it, he has the tools to fix easy
  4. #4 Re: Snapping studs?
    when i did my headers i could care less if they broke. kinda hoped they would all snap off. but only two snapped one on each cross over flange.
    in your case, id spray the nuts and studs with you fav penetrating oil for a few days and nights, then wire brush the stud threads to get the rust off.
    re spray the bolts warm up the car then try to crack em free. hot nuts tend to come off better.
  5. #5 Re: Snapping studs?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by ScottyDoggs View Post
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: Snapping studs?
    Buffalo
    Tighten slightly first to break the seal.
    get header bolt kit. I did. No more studs getting in the way for plug changes
  7. #7 Re: Snapping studs?
    SWPA
    I know it's a different car but my Stealth has 195k miles and has been sitting for 4.5 years and I didn't snap a single exhaust stud when I removed my manifolds.
  8. #8 Re: Snapping studs?
    The chances are slim. This from someone that has done this first hand a lot of times. Out of all the 3800's I've worked on, I've had two studs going into the head that broke and one of those was broken when it arrived. The bolts you want to concern yourself with are the crossover to manifold bolts. Loosen one a turn or two and then loosen the other equally until there isn't pressure on them.
    And ...If they do break they go into the manifold you are taking off, so no worries.
    I never worry about taking off exhaust into the head studs. They are made of good metal and not Ford studs. If you have concerns, take them out while the engine is still warm from driving.
  9. #9 Re: Snapping studs?
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I just put a set of SD headers in last week. My car has 118k miles on it and the only thing that gave me trouble was one cat back flange bolt, which you won't be dealing with.
    I was worried about the exhaust studs as well, but they came out easy. Same with the crossover bolts. Just for peace of mind I sprayed PB Blaster all over them for a few days before and had zero issues taking them out and reusing them.
  10. #10 Re: Snapping studs?
    Feb 2014
    Rhode Island
    I gotta say thanks for the tips and good stories, i read horror story after horror story of snapping the studs and I got really paranoid of doing the manifold.
  11. #11 Re: Snapping studs?
    the bolts in the heads come right out. had my headers off twice now.
    a 13 mm ratcheting wrench is you best friend for them bolts.
  12. #12 Re: Snapping studs?
    Apr 2009
    Upper Darby, PA
    I put off my install for like 4 months for the same reason. Once you get into it you realize it's no big deal. Just a bunch of bolts/nuts.
  13. #13 Re: Snapping studs?
    nothing has snapped on the engine at all so far. and ive been deep into it.
    only bolts that can be a problem are the cross over bolts, down pipe bolts and the cat back bolts. the threads rust and all the heat kills them. ive replaced my cat back bolts a few times, 90% of the time i just cut the bolts off and put a new one in there.
  14. #14 Re: Snapping studs?
    Feb 2014
    Rhode Island
    Luckily the catback and downpipe were put in a few months ago professionally haha so I only need to deal with the front manifold
  1. Using Studs such as ARP
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2015, 08:43 AM
  2. Snapping sound from alternator area and car won't rev past 3500 ?
    By wb22rules in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-13-2014, 08:11 PM
  3. D/S Halfshaft not snapping in
    By outonthetiles in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2012, 11:18 PM
  4. Where to get 3.8 ARP Studs?????
    By lambokit in forum General Tech Discussion
    Last Post: 05-12-2010, 11:18 AM
  5. Studs
    By wrfdff4 in forum Tires & Wheels
    Last Post: 03-31-2008, 11:16 PM
