Thread: Spark plug change and now runs like ****
Results 1 to 20 of 21
  1. #1 Spark plug change and now runs like ****
    Jul 2015
    USA
    Ok well it doesn't run awful, idles great and under normal driving conditions all is good. But when I accelerate hard, it misfires and runs awful. When I pulled out the plugs it had the auto lite 104s, I put it some decent ngk plugs but I know the supercharger is stock. So my question is what kind of mods could have been done to this car that won't let it run right on the plugs I put in? The gap is correct, any thoughts? Thanks.
  2. #2 Re: Spark plug change and now runs like ****
    Nov 2012
    Madison
    what are the decent ngk plugs?
    Are you throwing codes?
    maybe you have the vacuum leak mod
  3. #3 Re: Spark plug change and now runs like ****
    Jul 2015
    USA
    Iridium plugs, what is the vacuum leak mod?
  4. #4 Re: Spark plug change and now runs like ****
    Jul 2015
    USA
    No flashing engine lights, but I'll have it scanned tomorrow.
  5. #5 Re: Spark plug change and now runs like ****
    A plug may be cracked or a wire is causing the issue, but it's hard to just guess at it.
  6. #6 Re: Spark plug change and now runs like ****
    Nov 2012
    Madison
    I was just saying maybe you bumped a vacuum line wrestling with the plugs.
    Did you reuse the wires?
  7. #7 Re: Spark plug change and now runs like ****
    Jul 2015
    USA
    I'll take a look at the vacuum line, I did reuse the wires but it just seemed so odd that it did that right after I changed them. I know autolite 104s are the go to plug on these motors so I thought maybe if it was chipped or something like that.
  8. #8 Re: Spark plug change and now runs like ****
    SWPA
    I bet you cracked #6 plug on install. Happened to me twice because that damn o2 sensor causes a bad angle.
  9. #9 Re: Spark plug change and now runs like ****
    Quote Originally Posted by 2002gtp3 View Post
    your wires are dead, change them. i bet one or more pulled apart inside the boot end. cheap parts store wires work just fine too. no need to go nuts on wires.
  10. #10 Re: Spark plug change and now runs like ****
    Dec 2013
    ohio
    If were guessing I call plug wire going bad. They pull off hard when they have been on long time.
  11. #11 Re: Spark plug change and now runs like ****
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    little bit of boot grease goes a very long way.
  12. #12 Re: Spark plug change and now runs like ****
    GTP Level Member
    springfield IL
    always change wires and plugs at the same time!!!
  13. #13 Re: Spark plug change and now runs like ****
    Antioch, IL
    Why I dont need to change wires every 10-15k
    2009 Challenger SRT8
    Expert at being gay.
  14. #14 Re: Spark plug change and now runs like ****
    Apr 2015
    Columbus, OH
    Does it make a ticking kind of noise too? I bet its wires too. You will hear them arcing against your manifolds and such and it will fall on power like someone just pulled a plug wire on ya.
    Top Swapped 01 Imp
  15. #15 Re: Spark plug change and now runs like ****
    Quote Originally Posted by ITHURTZ View Post
    Because not everyone is special like you
  16. #16 Re: Spark plug change and now runs like ****
    Jul 2015
    USA
    Thanks for all the help guys, I'm on my way to pick up plug wires now. Hopefully that's the trick. Traded a 94 firebird formula with 150,000 miles for this 02 gtp with 98,000 miles. I'm liking it so far.
  17. #17 Re: Spark plug change and now runs like ****
    your liking fwd? ok, thats a first lol only thing in your favor is the gp is newer. they be peppy cars, but lack the potential of a rwd car.
    get them cheap lifetime replacement store brand wires, its what most of use use.
  18. #18 Re: Spark plug change and now runs like ****
    Antioch, IL
    Quote Originally Posted by blueguy View Post
    It should be a rule
  19. #19 Re: Spark plug change and now runs like ****
    Jul 2015
    USA
    Well I most likely the fact that it'll be better in the winter than my firebird haha. It was a bad wire, thanks for all the help!
  20. #20 Re: Spark plug change and now runs like ****
    if you ask me these cars suck in snow pretty bad. but i got into my regal after driving full size 4x4 gm trucks for twn years and i snow plowed, so im kinda used to sticking to the ground and being able to move, if not for snow tires it would sit every storm.
  1. Spark Plug ?
    By reno in forum Introductions/Noob Questions
    Last Post: 07-12-2013, 08:40 PM
  2. what spark plug should i get.
    By jakeb157 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2013, 07:04 PM
  3. P0443 and P0102 after spark plug change
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2010, 07:58 PM
  4. 1989 Grand Prix Spark plug change HELP
    By Kryptic in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-23-2008, 11:54 AM
  5. Corolla spark plug wire change (general maint. question)
    By 04CompG in forum Off Topic Discussion
    Last Post: 09-16-2008, 03:21 PM
