Thread: Rough Idle After Header Install
Results 1 to 20 of 26
  1. #1 Rough Idle After Header Install
    Donating Users isukathalo93's Avatar
    Sep 2012
    Waterford MI
    After a near impossible SD Header install on my 06 GT i got everything hooked up and started her up... But the engine is shaking pretty bad to the point where you can feel it while sitting in the driver seat. The idle will stay consistent than stumble for a second. The CEL is on but even if it was running fine it would be on because i'm cat-less. I'm to afraid to drive it up to the autoparts store to get the codes read. The seal between the headers and the EGR tube has an exhaust leak but idk if that has anything to do with it.. Any suggestions on what i should look for?
  2. #2 Re: Rough Idle After Header Install
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    id check plug wires/connections
  3. #3 Re: Rough Idle After Header Install
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Make sure everything is installed correctly maybe in your excitement for new parts you forgot something it happens to everyone some time or another
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: Rough Idle After Header Install
    did you take the spark plugs out for the install and removal of the stock crap? if not you cracked a plug or two easy.
  5. #5 Re: Rough Idle After Header Install
    Sep 2012
    Waterford MI
    I did not so i will definitely check those out.. If anything it would probably be one of the rears. I was also looking up vacuum leaks as well, seeing as i was laying on top of the motor, and if i do recall some of those lines looked pretty brittle. Would the EGR not being sealed to the headers have anything to do with it? or no.
  6. #6 Re: Rough Idle After Header Install
    the egr needs to be hooked up. and its a loud ass exhaust leak too.
  7. #7 Re: Rough Idle After Header Install
    Sep 2012
    Waterford MI
    Haha well yeah the loud exhaust leak is a little hard to miss I was just curious if it was contributing to my performance issues is all i know i need to seal it. The problem is i work 7-6 pretty much 5 days a week so i don't have tons of time after work to mess around with stuff. But i will definitely check plugs tomorrow. On a side note i don't think i will ever install headers again on any car.. What a pain. I had to cut a few inches off the connecting pipe from front to rear manifold just to get it to work.
  8. #8 Re: Rough Idle After Header Install
    i feel for all you guys, mine installed two times with no real issues.
  9. #9 Re: Rough Idle After Header Install
    Sep 2012
    Waterford MI
    I'm pretty sure the only thing that went smoothly was that i didn't need to dent the firewall for the o2 sensor. It has a decent clearance between it and the firewall. Oh and i could squeeze the pipe past the trans dipstick.
  10. #10 Re: Rough Idle After Header Install
    mine kjust cleared too, but when the engine moves it will hit the fire wall. most will hear it hitting when in reverse on the brakes. i know i did. bent the crap out of it too.
  11. #11 Re: Rough Idle After Header Install
    Sep 2012
    Waterford MI
    I don't suppose anyone makes shorter o2 sensors do they?
  12. #12 Re: Rough Idle After Header Install
    it just as easy to beat the fire wall. or move it to the cross over pipe. what i did.
  13. #13 Re: Rough Idle After Header Install
    May 2011
    Illinois
    nah, move the bung. dont monkey around trying anything else...unless clearancing the firewall will help...should try that first.
  14. #14 Re: Rough Idle After Header Install
    Sep 2012
    Waterford MI
    Im a little fed up with exhaust work right now haha. My first concern is gonna be getting my engine to run right.
  15. #15 Re: Rough Idle After Header Install
    May 2011
    Illinois
    fix the leaks you know you have first. dbl check your vac lines too.
  16. #16 Re: Rough Idle After Header Install
    i had that leak, my coin flew off on me when i blocked it, it will affect how the engine feels.
  17. #17 Re: Rough Idle After Header Install
    Sep 2012
    Waterford MI
    Ive heard bad things about blocking off the EGR so i'm a little weary to try it.
  18. #18 Re: Rough Idle After Header Install
    May 2011
    Illinois
    youv'e heard bad things about stopping exhaust carbon from entering your intake?
  19. #19 Re: Rough Idle After Header Install
    Sep 2012
    Waterford MI
    Oh so that's why the back of my throttle plate and intake are coated black? -__- here i thought they were painted lol. I ended up cleaning up my throttle body once i seen how bad it was the other day. And as far as the EGR delete goes ive heard it raises combustion chamber temps if you delete it.
  20. #20 Re: Rough Idle After Header Install
    mines blocked off, but you want to delete it from the pcm so it sets no codes.
  1. P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    By nskyline34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 07:49 PM
  2. Reverse Rough After header installation
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-20-2012, 10:55 PM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
  5. Rough Idle/Stumble after LIM Install
    By hesersypb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 08:27 AM
