Thread: Engine Trouble
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Engine Trouble
    Jul 2015
    Michigan
    It's been in for about 2 months. It ran fine the whole time. This literally just came out of nowhere. I was just cruising along and it just went.
    The company I purchased the motor from has has a warranty. They're sending me a new motor. Fingers crossed it's not another **** one. I'll be doing the swap myself. I can do **** like that, but trying to figure out what the hell's wrong when it could be a hundred different things causing the same problem annoys me.
  2. #22 Re: Engine Trouble
    no compression can only be a few things really. chipped piston, bad valves, or burnt rings.
  3. #23 Re: Engine Trouble
    Jul 2015
    Michigan
    Right. But it would've been too expensive to fix had I not got another motor due to warranty.
    I'm just thinking that's gotta be the case, the motor they gave me wasn't supercharged and the boost was just too much for it. It's the only thing that makes sense to me. Unless they lied about the mileage like I said. 3800's are strong motors, they don't just fall apart like that unless something isn't right.
  4. #24 Re: Engine Trouble
    the junk yards not gonna top swap a block and sell it, they rip em out and sell as is. you got a unlucky engine is all, it sucks but can happen when buying a used engine, just be glad they will replace the engine for you under warranty.
    and many here run top swaps. im am one of them now. runs fine.
  1. 98 gtp new guy engine trouble
    By JayHolyj in forum Introductions/Noob Questions
    Last Post: 02-20-2012, 11:58 AM
  2. Engine trouble?
    By DCGTP in forum General Tech Discussion
    Last Post: 01-25-2012, 01:57 PM
  3. 3.8 engine trouble
    By mjacob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2011, 11:37 AM
  4. Engine Trouble
    By 98GTFan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-10-2011, 03:58 PM
  5. Engine Trouble!! need help!
    By ddrum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2010, 04:41 PM
