Thread: High hp?
Results 1 to 9 of 9
  1. #1 High hp?
    Jun 2015
    missouri
    So guys, new to the forum and could use some help. Im looking to build a 97-99 gtp coupe. Here is my plan on the build so far:
    http://www.3800performance.com/Merch...roduct_Count=5 Stage 6
    ported heads
    http://www.3800performance.com/Merch...roduct_Count=3 coil packs
    http://www.3800performance.com/Merch...roduct_Count=2 head studs
    http://www.3800performance.com/Merch...roduct_Count=4 better m90
    http://www.3800performance.com/Merch...roduct_Count=1 slp thermostat
    this seems like a good start, but what else am i missing to make high HP? except for NOS. thanks and have a great day
  2. #2 Re: High hp?
    Mar 2012
    NC
    You're missing the most vital parts...a built trans and a turbo kit.
  3. #3 Re: High hp?
    Kits cost too much, you can piece together parts for cheaper.
    MSD coils are junk, factory coils are far better and will not cause problems.
    A Used GEN 5 supercharger can be had for 200-350 bucks most of the time, just paint it if you want a different color.
    In the end your weak link is the transmission, after a 3.4ish pulley size with maybe 250+ wheel horsepower your trans becomes the part that you'd worry most about.
  4. #4 Re: High hp?
    Jun 2015
    missouri
    so what would you recommend for a 11 sec car? obviously built trans
  5. #5 Re: High hp?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by sideways99 View Post
    If all you care about is numbers than spray it. Going e85 could also get you there but not without a lot of help. Cam, Headers, Nitrous.
    Oh and trans.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  6. #6 Re: High hp?
    Turbo.
    You'll never reach 11's easily with a supercharger or if at all.
  7. #7 Re: High hp?
    Jun 2015
    missouri
    ok thanks. I found a gtp for 1k that needs a new strut. Might pick it up
  8. #8 Re: High hp?
    I'd just make it a quick car and something to bum around in.
    Because honestly if you are dead set on going fast, get something RWD because you'll dump way too much money into something that is heavy and FWD.
  9. #9 Re: High hp?
    Jun 2015
    missouri
    thats the plan. I recently bought a mustang gt. This car is meant to be a " sleeper ". its not gonna be out whoopin beater bomb and fr8trn, but will suprise most of the street cars out there
  1. low 14s maybe high 13s?
    By BlackGT97 in forum General Tech Discussion
    Last Post: 09-11-2011, 07:39 AM
  2. How high should a L67 be able to rev up...
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2010, 06:49 PM
  3. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
