Thread: low 14s maybe high 13s?
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 low 14s maybe high 13s?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    n/a
    hv3
    headers
    cam (not sure which one, but biggest one i can)
    1.6 roller rockers ( do rrs increase lift with stock ratio?)
    additional exhaust work
    open cone
    maybe increase compression 10:1 (info on this would be helpful.) note, i have not read up on this (increasing compression)
    shift kit
    and a nice tune
  2. #2 Re: low 14s maybe high 13s?
    is that a question or a statement?
    SMGPFC Member #10
  3. #3 Re: low 14s maybe high 13s?
    Omaha, NE
    Is there a question somewhere in this thread?
    Edit: Ninja'd
  4. #4 Re: low 14s maybe high 13s?
    HA!!
    SMGPFC Member #10
  5. #5 Re: low 14s maybe high 13s?
    SE Level Member cannon's Avatar
    Jul 2010
    Benson, MN
    I duz not understand thread question. If there even is one
  6. #6 Re: low 14s maybe high 13s?
    Florida
    Im pretty sure he's askin a question with the key word "maybe" and his title containing a question mark.But OP i doubt youll crack the 13's with that setup. Goin with a GT2 cam and head work then the rest of those mods minus rockers you may get to low 14's but you''ll need spray to crack 13's.
  7. #7 Re: low 14s maybe high 13s?
    Jul 2011
    Michigan
    Quote Originally Posted by dmahlikGT View Post
    im inpressed. fist one so far to not need the question spoonfed. any other mods that would help get me there besides spray?
  8. #8 Re: low 14s maybe high 13s?
    Jul 2011
    Michigan
    looking into the title, there seems to be a question mark.
  9. #9 Re: low 14s maybe high 13s?
    Omaha, NE
    That's not even a question. Its an incomplete sentence.
    Are you trying to ask if that "mod list" if we can even call it that will get you into the low 14s or high 13s?
  10. #10 Re: low 14s maybe high 13s?
    Jul 2010
    Benson, MN
    But in that case you might as well S/C or turbo, cuz heads are spendy
  11. #11 Re: low 14s maybe high 13s?
    Jul 2011
    Michigan
    ill spoon feed it. QUESTION, WHERE WOULD THESE MODS (if we can call it that) PUT ME FOR TIME IN THE QUARTER MILE. LOW 14s OR HIGH 13s. LOL
  12. #12 Re: low 14s maybe high 13s?
    Jul 2010
    Benson, MN
    Id say mid 14's to be conserative. Most people look at the kind of money they would have to spend to be fast n/a, and just give up
  13. #13 Re: low 14s maybe high 13s?
    Omaha, NE
    Thank you for spoon feeding me that question, and by spoon feeding me, I mean asking an actual question like anyone else who uses this forum.
    I'd say you would be around 15 flat with that mod list in the 1/4.
  14. #14 Re: low 14s maybe high 13s?
    Jul 2010
    Benson, MN
    THIS. but back to the topic
  15. #15 Re: low 14s maybe high 13s?
    Florida
    Really spade? lol. Are you Serious about that? Nooo wayy.To answer your last question OP the only other way besides spray i can think of is weight reduction and a gear swap (3.69's).But like others said boost gets you further easier.Supercharge or turbo is better ways.
  16. #16 Re: low 14s maybe high 13s?
    Jul 2010
    Benson, MN
    Well what times are you at for the 1/4. Seems like you have a pretty stout n/a
  17. #17 Re: low 14s maybe high 13s?
    Florida
    @ spade for sayin he'll run a 15 flat.Ive seen lightly modded GT's run that and faster. And the guy above im not sure exactly what i run yet, I will be going to the track soon. I have timed my 0-90 runs a few times as an idea being 88-92 is trap speed for our cars stockish and currently my 0-90 is 14.8ish sec.Thats the fastest so far with my sig mods.
  18. #18 Re: low 14s maybe high 13s?
    Omaha, NE
    You should use the search and find other N/A build questions. Most realize its a waste and don't bother.
  19. #19 Re: low 14s maybe high 13s?
    Omaha, NE
    Serious about what?
  20. #20 Re: low 14s maybe high 13s?
    Omaha, NE
    Exhaust mods hurt N/A 3800s.
    Without being spoon fed any information on the car, year/ mileage, to factor in the amount of carbon build up it probably has or wear on fuel pump, injectors etc. I could see a car with those mods being 14.8- 15.0
  1. How high should a L67 be able to rev up...
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2010, 06:49 PM
  2. High NOX
    By Justin48 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 08:00 AM
  3. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
  4. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
