Thread: Fuel pump not getting power
Results 1 to 12 of 12
  1. #1 Fuel pump not getting power
    Banned
    Jan 2013
    Colorado
    So the pump isn't turning on. I can't hear the whine sound from it. I tested one wire and it was at 5 volts or so but the pump wasn't turning on. Is my pump just dead?
  2. #2 Re: Fuel pump not getting power
    will it start and stall? if so that the high speed relay gone bad. if its just dead and you tried swapping th erelays in the fuse box already the pump is dead.
    try hitting the bottom of the gas tank with you palm. rather firm, sometimes it will shock the pump back to life. its a temp fix, dont trust it if it fires up after you hit the tank.
  3. #3 Re: Fuel pump not getting power
    Jun 2013
    United States
    Had the start stall thing with mine a few months back. I thought fp also but it was the speed sensor in the front bumper.
  4. #4 Re: Fuel pump not getting power
    GXP Level Member
    Mar 2015
    Tomball
    Another member posted this same problem and his socket for the relay is worn out. He also had 5V but was actually measuring the sender voltage not the one for the pump.
    Jeff
  5. #5 Re: Fuel pump not getting power
    Banned
    Jan 2013
    Colorado
    negative, does not start at all. i've tried that relay trick too, did nothing.
  6. #6 Re: Fuel pump not getting power
    GXP Level Member
    Mar 2015
    Tomball
    When you tried the relay trick did you check to see if you're getting 12V at the pump?
  7. #7 Re: Fuel pump not getting power
    Banned
    Jan 2013
    Colorado
    i did not
  8. #8 Re: Fuel pump not getting power
    Banned
    Jan 2013
    Colorado
    will this work as a replacement pump?
    http://www.ebay.com/itm/380876574426...%3AMEBIDX%3AIT
  9. #9 Re: Fuel pump not getting power
    Banned
    Jan 2013
    Colorado
    so my pump still isn't getting power, relay trick doesn't work. Fuse isn't blown. Tested the wires all the way till they went into a bigger loom near the front. No power. Hot wired the pump and it turns on fine. Car still won't turn over though.
  10. #10 Re: Fuel pump not getting power
    GXP Level Member
    Mar 2015
    Tomball
    Sounds like you need to check into that bigger loom near the front. If you cannot check continuity from the fuel pump wire to the relay then you have a break somewhere.
    Jeff
  11. #11 Re: Fuel pump not getting power
    GT Level Member mguzzo's Avatar
    Buffalo NY
    did you jumper the fuel pump relay in the underhood fuse box?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  12. #12 Re: Fuel pump not getting power
    Banned
    Jan 2013
    Colorado
    yes, I tried that guzzo
  1. 01 SE no power to fuel pump
    By Ketterer in forum General Grand Prix Discussion
    Last Post: 02-04-2014, 10:47 PM
  2. 02 GT - No power going to fuel pump
    By TrucifiX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2013, 12:00 AM
  3. no power to fuel pump ????
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 07:00 PM
  4. no power to fuel pump ????
    By icolex1 in forum General Tech Discussion
    Last Post: 03-16-2010, 07:16 PM
  5. no power to fuel pump HELP
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 03:46 PM
