Thread: no power to fuel pump ????
Results 1 to 4 of 4
  1. #1 no power to fuel pump ????
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    so my wife runs the car with the "low fuel" light on for a little too long, she turns it off or it dies at the fuel pump, she puts gas in it and tries to start it, i find it pushed into the haddicapped spot at sheets when i get off work, I check the fuel rail and get nothing, checked the relay and switched it with the AC blower relay nothing, i even bent the prong back to engage the high speed pump to see if that worked....nothing(i think bending the prong for the relay is only for the gtp...not sure,but tried it anyway) so......
    I then went and bought a fuel pump and installed it and ........
    .......nothing
    now what....
    is there another fuse....
    is there a fuel reset saftey switch
    hydro-powered
  2. #2 Re: no power to fuel pump ????
    Willoughby, Ohio
    maybe you should try bypassing the fuel pump resitor. and check the fuel pressure regulator
  3. #3 Re: no power to fuel pump ????
    Feb 2009
    Highspire,PA
    found it, was a fuse, fuse is located in the same spot as the relay, boy do I feel like an idiot for not looking in the book for the location of the fuel pump fuse.
    expensive mistake fuel pump was probably good, well I 've got a back up
    hydro-powered
  4. #4 Re: no power to fuel pump ????
    Willoughby, Ohio
    ^^^ i kind of assumed you already looked at the fuse, i guess you and i both jumped to conclusions
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. no power to fuel pump ????
    By icolex1 in forum General Tech Discussion
    Last Post: 03-16-2010, 07:16 PM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  4. no power to fuel pump HELP
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 03:46 PM
