Thread: dry ice intercooler
Results 1 to 20 of 33
  1. #1 dry ice intercooler
    Kemmerer, Wyoming
    thinking about adding a 97/98 coolant overflow to my intercooler system so I can put dry ice in it for the drag strip. setup is a ported gen 3 m90 with a phenolic intercooler, ported L32 heads and an xp cam.
    will the dry ice freeze the coolant?
    anyone else done this?
  2. #2 Re: dry ice intercooler
    SWPA
  3. #3 Re: dry ice intercooler
    Feb 2013
    37.295091, -121.930053
    lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: dry ice intercooler
    Kemmerer, Wyoming
    I did read that before posting this thread
  5. #5 Re: dry ice intercooler
    GXP Level Member
    Mar 2015
    Tomball
    I don't think it would work as well as you think it would. I would have the coolant flow through a radiator type container that you can put dry ice in and the coolant flows through tubes that are surrounded by dry ice. Kinda like that website has but with coolant going through where the air flows and the box like he has it. Hell I could make one from SST.
    Jeff
  6. #6 Re: dry ice intercooler
    Kemmerer, Wyoming
    Quote Originally Posted by J57ltr View Post
    Jeff
    what's SST? my brain didn't compute what I read until I went and watched the video again, then it made sense. Why wouldn't it work very good?
  7. #7 Re: dry ice intercooler
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by SgtMarshal View Post
    your original idea of just dumping the dry ice in the coolant tank, it will sublimate too fast and you would need a good vent to allow it to expand. I can't remember but I think it was like 400 times the volume from a solid to gas.
    SST is short for stainless steel. I have lots of it at work. It could be made small enough to cool the coolant after the heat exchanger you already have.
    I made a supplemental cooler using Peltier modules years ago and could drop the temp of 165* water down to 70* but it drew nearly 75 amps and you had to have another heat exchanger and pump so it wasn't really practical.
    Jeff
  8. #8 Re: dry ice intercooler
    Dec 2013
    ohio
    Rear mount the battery. Where it use to be make your container (start with alum battery box) and run your lines through it on the way back from inter cooler radiator. Just a thought.
  9. #9 Re: dry ice intercooler
    Feb 2013
    i would go with a liquid nitrogen set-up that way you know its cold lol
  10. #10 Re: dry ice intercooler
    Kemmerer, Wyoming
    I wonder if there is a way to retrofit that dry ice intercooler for it to work on a liquid to air system
  11. #11 Re: dry ice intercooler
    GXP Level Member
    Mar 2015
    Tomball
    Yes like I described that way you can either run dry ice or not, for the track you won't need a lot for each run. If you want I could draw you one up in Acad.
    Jeff
  12. #12 Re: dry ice intercooler
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Years back I remember a guy mounting an ice chest in his spare tire well, ran his IC in/out lines to it. At the track he'd fill it with ice, it had a drain that ran through the drain hole that's there for the spare. I guess even for normal use you got extra cooling effect just from the length of the lines and the extra capacity of the system. Only downside is, depending on where you drive, a line could get cut or something if you don't have it routed/protected fairly well.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  13. #13 Re: dry ice intercooler
    Buffalo
    I posted a setup I use for the tib a while back that I have yet to do with regal
    perfect sizes reservoir for your idea
  14. #14 Re: dry ice intercooler
    hangover park IL
    n2o
    Done.
    ~James~ Psychotic Gearhead
  15. #15 Re: dry ice intercooler
    Buffalo
    Others have routed a 2nd heat exchanger into the trunk. Placed inside a cooler. Fill the cooler with ice water , and run a hose to drain it when it's melted.
    Kinda cool to see condensation the IC core -'see cgp for more info
  16. #16 Re: dry ice intercooler
    Buffalo
    so you could drain it, and run water and ice
  17. #17 Re: dry ice intercooler
    Kemmerer, Wyoming
    I think I am going to stick with methanol or nitrous when I end up doing another mod
  18. #18 Re: dry ice intercooler
    GXP Level Member
    Mar 2015
    Tomball
    More bang for your buck.
  19. #19 Re: dry ice intercooler
    Banned
    Jan 2013
    maryland
    Nitrous 150wet shot!!!
  20. #20 Re: dry ice intercooler
    Kemmerer, Wyoming
    Quote Originally Posted by jayroca View Post
    dont think my trans would like that much, but I haven't ruled out nitrous.
  1. Air to air intercooler
    By matt5112 in forum General Tech Discussion
    Last Post: 08-08-2012, 08:11 AM
  2. ZZP intercooler
    By MoarkatsINmuhtrailer in forum General Tech Discussion
    Last Post: 06-22-2012, 01:02 PM
  3. air to air intercooler
    By asite57 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2012, 12:34 PM
  4. new intercooler??
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 11:11 AM
  5. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
