Thread: 97 GTP Cai
Results 1 to 6 of 6
  1. #1 97 GTP Cai
    Apr 2015
    Lincoln NE
    I installed a cai on my 97 gtp. However it doesn't seem to be running as well now. Scanning it doesn't seem to show anything out of the ordinary though. Any ideas?
  2. #2 Re: 97 GTP Cai
    You probably broke a vac line or forgot to plug something back in.
    Here is a vac diagram so you know where the lines are and where they go to. Don't pay attention to the line that says to trans, I am not aware of any 97 GTP with a vacuum actuated trans.
  3. #3 Re: 97 GTP Cai
    Apr 2015
    Lincoln NE
    All of the vacuum lines seem to be in order. The boost gauge doesn't fill but 3/4 under about 4000rpm. It jusy seems to be lacking low end power
  4. #4 Re: 97 GTP Cai
    You most likely broke a vac line. Spray around the vac lines with some carb cleaner.
  5. #5 Re: 97 GTP Cai
    Apr 2015
    Lincoln NE
    I'm not seeing any leaks but I'll try again when I have more time. Any other suggestions?
  6. #6 Re: 97 GTP Cai
    Double check your wiring, make sure nothing is broke.
