Thread: Need a bit of advice
Results 1 to 13 of 13
  1. #1 Need a bit of advice
    SE Level Member Efrain55's Avatar
    May 2015
    So me and my friend changed my water pump today because the car has been leaking coolant and all the coolant elbows are still good. After replacing it and putting everything back together for some reason the electronic boost gauge in the driver info part don't work anymore. Anybody know why it could of went out?
  2. #2 Re: Need a bit of advice
    GXP Level Member
    Mar 2015
    Tomball
    What do you mean it doesn't work? Is it not there or just doesn't move. My guess is that you knocked the vacuum lune loose under the snout of the supercharger if it's just not moving.
    Jeff
  3. #3 Re: Need a bit of advice
    May 2015
    It still pops up but it doesn't show how much boost. Something went wrong because now the car is misfiring
  4. #4 Re: Need a bit of advice
    May 2015
    I'll have to take another look tomorrow.. I'm a noob at these cars I just got my gtp so I'll catch on eventually lol
  5. #5 Re: Need a bit of advice
    St. Louis
    Did you remove any of the plug wires when you changed the water pump? If so, check your firing order. These cars will still run even if 2 or more cylinders are wired wrong and often only show a misfire when you are driving it. I reversed 2 of mine once and it idled just fine with no CEL, then I drove it... Misfire city.
  6. #6 Re: Need a bit of advice
    May 2015
    I appreciate the help. I'll take a better look when I get off work
  7. #7 Re: Need a bit of advice
    May 2015
    It ended up just being the vacuum line under the super charger. Car is running good now thanks for the help!
  8. #8 Re: Need a bit of advice
    May 2015
    What kind of oil would you guys recommend to use on these cars?
  9. #9 Re: Need a bit of advice
    GXP Level Member
    Mar 2015
    Tomball
    I am a little more old school so I have never run a synthetic unless called for by the manufacturer. I also don't change my oil every 3K either.
    Jeff
    Edit: I have my reasons, mainly because I have watched cheap brands bottled at the same time as higher end brands without changing the actual product (just the bottle), but I have never had an engine related failure and have pulled down engines for performance heads, cams and things and have had engines with more than 150K with good crosshatching.
  10. #10 Re: Need a bit of advice
    GXP Level Member
    Mar 2015
    Tomball
    Like motor oil? Motor oil is motor oil. Supercharger oil? Pick up some at the stealership.
    Jeff
  11. #11 Re: Need a bit of advice
    May 2015
    I was talking about engine oil but u went with a synthetic blend
  12. #12 Re: Need a bit of advice
    May 2015
    I not u
  13. #13 Re: Need a bit of advice
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I run Mobil super 5k in everything I have except the G8, that gets M1 extended performance.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. Car advice pls
    By Fox in forum General Grand Prix Discussion
    Last Post: 11-13-2013, 11:48 PM
  2. Need E85 advice please
    By Ultra440 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2012, 07:09 PM
  3. Need some advice...
    By WOTFTW in forum General Tech Discussion
    Last Post: 10-28-2010, 07:03 PM
  4. GXP advice?????
    By FatDog in forum Off Topic Discussion
    Last Post: 10-24-2010, 11:34 PM
  5. **please help, need advice**
    By tmackster in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2010, 11:40 AM
