Did you remove any of the plug wires when you changed the water pump? If so, check your firing order. These cars will still run even if 2 or more cylinders are wired wrong and often only show a misfire when you are driving it. I reversed 2 of mine once and it idled just fine with no CEL, then I drove it... Misfire city.
