Thread: Oil Pressure too high???
Results 1 to 9 of 9
  1. #1 Oil Pressure too high???
    Feb 2013
    Missouri
    Hey guys,
    I installed a Glowshift oil pressure gauge and it's showing ~85-90 PSI at cold idle. After about 10-15 min of driving it'll drop to ~50-55PSI when it warms up a bit. Glowshift is saying this is totally acceptable. What do you guys think? I've changed the oil filter to be safe.
  2. #2 Re: Oil Pressure too high???
    GXP Level Member
    Mar 2015
    Tomball
    What weight motor oil are you using and how tight is your engine. On a new or very well maintained that is not uncommon.
    Jeff
  3. #3 Re: Oil Pressure too high???
    Feb 2013
    Missouri
    Not sure on how many miles is on the motor, I got conflicting info from the junkyard. Every thing looked to be in very good shape when I put new gaskets on stuff, so I would think it's pretty low. I believe it has 5w-30 in it.
  4. #4 Re: Oil Pressure too high???
    I would think that the gauge is a bit off. I wouldn't be worried about the motor.
  5. #5 Re: Oil Pressure too high???
    GXP Level Member
    Mar 2015
    Tomball
    It's about 10 psi higher than I usually see but I wouldn't be concerned with it, maybe gauge is off.
    Jeff
  6. #6 Re: Oil Pressure too high???
    Feb 2013
    Missouri
    I'm gonna double check the wiring, but I'll probably just leave it. It's weird seeing the gauge max out at 100 PSI at 1,500 RPM lol.
  7. #7 Re: Oil Pressure too high???
    St. Louis
    I think you got what you paid for with the Glowsh*t gauge. If it keeps up, stick an Autometer in there. Never had an issue with mine. My 00GT pushes ~70lbs cold, then drops to 50 or a bit below when full hot. And that's with 200K+ on it.
  8. #8 Re: Oil Pressure too high???
    Feb 2013
    37.295091, -121.930053
    i would worry about oil flow more than oil pressure. if you have no flow then you burn up your engine.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: Oil Pressure too high???
    GXP Level Member
    Mar 2015
    Tomball
    Pressure and flow are proportional unless there is a blockage.
    Jeff
  1. high pressure power steering hose 2006 3.8
    By tajacks2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2015, 05:58 PM
  2. High Pressure line stuck
    By HerpDerp1919 in forum General Tech Discussion
    Last Post: 02-28-2015, 10:38 PM
  3. Power steering high pressure line 04+
    By Javi in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2011, 09:37 AM
  4. High Oil Pressure
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2009, 02:44 PM
  5. Replies: 0
    Last Post: 08-09-2009, 07:01 PM
