I've searched but can not find anything quite like what's happening.
It's a 02 GP GTP with 170,000 miles.
When starting the car it will not stay running. Essentially the idle is to low. If I press down on the gas peddle 1/4" or so then turn over the engine the car will start and the idle will be around 1,000-1,500 and stay running. If I remove my foot from the gas peddle the idle will drop down to 300 and the car stalls out.
After reading other posts this is what I have done. I have already replaced the IAC (twice just in case one was bad), MAF (OEM), TPS (because after removing it and re-installing it was throwing a Check Engine warning).
Yesterday while driving I was hearing a whistling sound when the RPM's reached 1,800-1,900 under load going up hills.
Could that sound be a vacuum leak and if so could that cause what is happening. I'm not sure where to start looking if it is. All the hoses look fine. Should I just start removing all of the connections and check them one by one?
Any help would be appreciated.
Thanks,
Kurt
