Thread: low vacuum / PCV problem ?
Results 1 to 4 of 4
  1. #1 low vacuum / PCV problem ?
    Keene, NH
    Hello everyone. I just bought a '99 GTP, all stock, and I am getting P0171 lean bank 1 consistently...
    Got set up with a scan tool on my laptop and sure enough, the LTFT's sit at 16.4 at idle and slow cruise, they seem to lower when the engine is under more load.
    Except for 10 in/Hg at idle, all other sensors look good and I have started to examine the engine for vacuum leaks.
    I noticed that if I remove the oil filler cap while the engine is running I get a stumble out of the motor, and when I spray carb cleaner in the front valve cover, the motor does change rpm temporarily.
    Is this typical, or am I in the right area? Should I check the PCV system? The PCV valve itself is new.
    Thanks for any advice,
    Jason
  2. #2 Re: low vacuum / PCV problem ?
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    sounds like a vac leak I had the same problem with my ltft's being at 16.4. First it was my s/c gasket fixed that and still had a leak. Ended up being my oil dipstick was broke right were the o-ring is on the inside. Now they sit around 8 at idle but i also added rockers and a ic so i have to tune it now. It is normal for the idle to change when you take off the oil cap. Keep trying the carb cleaner and see if anywhere else is leaking. Also I was told if you scan your IAC and they are under 50 you have a leak.
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  3. #3 Re: low vacuum / PCV problem ?
    Keene, NH
    I am thinking that there is no o-ring on my PCV valve... Does this go on below the flare on the large end of the valve???
  4. #4 Re: low vacuum / PCV problem ?
    Oct 2008
    Northern Illinois
    It's a vac leak. Where you sprayed the cleaner and the rpm changed, that's where it is.
  1. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
  2. brake booster vacuum problem
    By comongoose in forum Brakes/Suspension/Chassis
    Last Post: 03-20-2009, 12:46 PM
  3. vacuum pressure problem
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 11:47 AM
  4. Vacuum hose
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 07:01 AM
  5. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
