Thread: Series II alternator
Results 1 to 5 of 5
  1. #1 Series II alternator
    Oct 2013
    United States
    Can I use the series III alternator from a 2006 Buick on a series II GP S/C? The amps of the Buick is 120 and the GP is 110 is there anything else that would effect anything?
  2. #2 Re: Series II alternator
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    jeremy,
    I run a 2004 Grand Prix (3800 series 3) alternator on my 2004 Impala (3800 series 2). Works perfectly. I believe the key will be making sure that the connectors and mounting is the same. Other than that, I don't see why not.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  3. #3 Re: Series II alternator
    Feb 2013
    Missouri
    Why not upgrade to a CS144? Better than a CS130 all day long.
  4. #4 Re: Series II alternator
    If you want an easy swap, go get a 2000-2003 Bonneville SSEi alternator. 125amps and usually cheap from a JY.
    As for running a newer buick alt on your gp, I believe the field etc is controlled differently by the pcm and that may be more of an issue to figure out than it's worth.
  5. #5 Re: Series II alternator
    Oct 2013
    United States
    The Buick had a 2 pin connector so it would not have worked, ended up going with one from a 2001 Bonneville. Apparently its been dying slowly for awhile now, lights are bright again and passenger window goes up with ease. Thank you
  1. Series II alternator
    By jeremy365 in forum General Grand Prix Discussion
    Last Post: 04-09-2015, 12:17 PM
  2. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  3. leaking coolant at TB, possible top swap with series 3 on to a series 2 block?
    By anarchy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2013, 03:54 PM
  4. Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    By Booba5185 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2013, 10:33 AM
  5. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
