Thread: Gp problems
Results 1 to 12 of 12
  1. #1 Gp problems
    SE Level Member Snoop dogg's Avatar
    Dec 2013
    chicago
    Hey guys I'm having a issue I have a 98 Grand Prix GTP stock and it's been ok until now well recently I did both control arms and the next day i noticed while driving on the expressway any were from 50-75 or trying to accelerate lightly the RPMs drop and the car starts to shake or flutter like a misfire until I let my foot off the gas or lightly press the brake then it goes back to normal just for a little bit & as far in street driving it does it after 35Mph i haven't had a clue what's going on I don't know if its the trans or engine any ideas
  2. #2 Re: Gp problems
    Mar 2015
    Nashville,Tn
    Sounds like a bad coil pack,MAF sensor or the throttle positioning sensor. Try unplugging the tps and see if that helps. Then you can try unplugging the MAF to see if it runs better.
  3. #3 Re: Gp problems
    Dec 2013
    chicago
    And i don't have a SES ON
  4. #4 Re: Gp problems
    Mar 2015
    Nashville,Tn
    I had some of the same conditions that you are having and I didn't have a light on either. But I started unplugging some sensors. My MAF didn't even set off a code.
  5. #5 Re: Gp problems
    Nov 2012
    Madison
    If you only messed with the suspension your alignment is probably off
  6. #6 Re: Gp problems
    Dec 2013
    chicago
    Well i was at work & now when I put it in gear it did not move then after a while it went into first gear and I started driving and it wouldn't shift out of first get back into the parking lot at my job and I want to put it in reverse and it wouldn't go in any gears turn the car off for a while started it back up and tried to move it again and it went into reverse & drive scared to drive it home but still do not know what's going on
  7. #7 Re: Gp problems
    SWPA
    Quote Originally Posted by spazzz View Post
    If he only messed with control arms his alignment should be unchanged.
  8. #8 Re: Gp problems
    new ball joints and bushings can and will make the alignment off. the steering wheel was off a few inches when i changed mine.
  9. #9 Re: Gp problems
    Dec 2013
    chicago
    It was off a bit but i dont think it wouldn't have messed with how the car runs
  10. #10 Re: Gp problems
    how its running is unrelated to the lca swap. try a tune up if its not been done.
  11. #11 Re: Gp problems
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    If you haven't already, check your trans fluid level (at operating temp, on a level surface). Top it off if it's low, then do a pan drop/filter change when you get it home. Before cleaning the pan up, get some pics of what's in it right after you remove it and post them up here. Also make sure your battery terminals are clean and tight (same way I like my women), corroded terminals and/or grounds will make the trans do funny stuff.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: Gp problems
    Dec 2013
    chicago
    hey guys I'm back well I found out what was going on with my trans so it needed to be rebuilt it was trashed what ended up happening was my cooler ended up getting clogged with metal shavings so the pump gave out and the tcc gave out so basically it burned out.
  1. '03 GT problems.
    By drivinfast247 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2013, 06:19 PM
  2. think i would have problems?
    By gtp leslie in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2011, 08:57 PM
  3. HID problems AGAIN
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 07-26-2010, 07:12 AM
  4. more problems...
    Last Post: 05-09-2009, 05:37 PM
  5. 2 problems need help with
    By kenneth74gt in forum General Tech Discussion
    Last Post: 04-19-2009, 02:21 AM
