Thread: Misfire cylinder 2(actually 1) only under load
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
  1. #1 Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    I have Aeroforce scan gauge and it indicates misfire only under heavy load for cylinder 2. For some reason my Aeroforce says 2 but its actually cylinder 1. If I pull cylinder 1 plug wire I get misfires displayed on scan gauge on cylinder 2. So cylinder 1 is 2 and 2 is 1 for the scan gauge..
    So what have a done.
    Replaced spark plug....no help
    Replaced plug wire.....no help
    Swapped coil packs.....no help
    Swapped ignition module....no help
    I'm getting sputtering under heavy acceleration.....50-80 misfires.
    What next? It gives no misfires under normal driving and light acceleration.
  2. #2 Re: Misfire cylinder 2(actually 1) only under load
    Donating Users timboku's Avatar
    Montgomery, IL
    Bad or clogged injector.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    Love the forum. That didn't occur to me.
  4. #4 Re: Misfire cylinder 2(actually 1) only under load
    Feb 2013
    Missouri
    Thats what I was going to say. I had those same problems and it was an injector problem.
  5. #5 Re: Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    put all six stock injectors back in and have the same problem same cylinder. Idles fine but this problem has been getting slowly worse, now under any kind of load I get a ton of misfire cylinder 1.
    Any one ever see a scan gauge show the wrong cylinder?
  6. #6 Re: Misfire cylinder 2(actually 1) only under load
    Feb 2013
    Missouri
    Are the connectors making a good connection? When I first bought my car the little clips inside the injector plug on the harness were too loose to make a good connection to the injector. I know it's a long shot, but it only takes a minute to check. I haven't had misfires show up on the wrong cylinder, but I don't use an aeroforce either. I almost wonder if it's confused since 1 is right after 2 in the firing order?
  7. #7 Re: Misfire cylinder 2(actually 1) only under load
    Montgomery, IL
    Do you have another way to chexk.mis mires using torque or dhp? Agree it may be a injector connector or britle wiring on connector.
  8. #8 Re: Misfire cylinder 2(actually 1) only under load
    Compression check is what I'd do now.
  9. #9 Re: Misfire cylinder 2(actually 1) only under load
    Mar 2015
    Nashville,Tn
    Could be a malfunctioning MAF sensor. Unplug it and drive your car to see if it helps.
  10. #10 Re: Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    I double checked the #1 connector on the injector and wires look good, nothing frayed, pulled or burned. Replaced all the coil packs and took it for a ride today. Ran great, though it was fixed but the engine wasn't all the way up to temperature. Turned around and wend back down and up a long hill and it was back, cylinder #2 misfire but not as high a count. I had absolutely no misfires with the engine below 150 degrees.
    I just put a big fan on the engine. I'm going to swap all the plugs and wires when it cools down. I will be heading to advance or autozone to get compression gauge if it still does it with all different plugs and wires.
    Can the PCM do weird stuff like this?
  11. #11 Re: Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
  12. #12 Re: Misfire cylinder 2(actually 1) only under load
    Feb 2013
    Missouri
    Sounds like being in closed loop vs. open loop has something to do with it. Might be a sensor of some sort. MAF and 02 are good?
  13. #13 Re: Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    #1 135psi
    #2 95psi
    #3 138psi
    #4 140psi
    #5 140psi
    #6 140psi
  14. #14 Re: Misfire cylinder 2(actually 1) only under load
    Feb 2013
    Missouri
    Son of a *****. You do a leak down test? Then you'll know if your doing heads or an engine at least.
  15. #15 Re: Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    Do I have to be at top dead center to put air pressure to the cylinder? Or can I just put pressure on it and have it spin its self to the bottom of stroke.
  16. #16 Re: Misfire cylinder 2(actually 1) only under load
    Bastard Reptile's Avatar
    Kansas City, MO
    It doesn't matter, once you put air to the cylinder it'll push the piston down and hold it.
  17. #17 Re: Misfire cylinder 2(actually 1) only under load
    Mar 2015
    USA
    I like to pull all the plugs so it's easier to turn the motor by hand. Take a small length of hose that fits in a sparkplug hole. Have a helper feel the end of the hose as you turn the motor by hand. If if no helper, do what I did and rob a squeaker out of a dog toy to shove in the end of the hose. Instant TDC locater.
    With motor at TDC for that cylinder, pump air into it while watching/listening for it in the intake, exhaust, crankcase, and cooling system.
    The piston needs to be at the top of its stroke, with both valves closed. If your not fully at TDC, the compressed air will turn the motor as it pushes the piston down.
  18. #18 Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    Okay, gave up on TDC #2. Pulled alternator, valve cover and both rocker arms. Put air to it and it is coming out the exhaust.
    No bubbles in coolant.
    Nothing coming out crankcase PCV hose.
    Nothing coming out the TB intake.
  19. #19 Re: Misfire cylinder 2(actually 1) only under load
    with the rocker off still hit the top of the valve with a mallet. it may seal, if it dont seal theres some thing wrong with that valve or its seat.
  20. #20 Re: Misfire cylinder 2(actually 1) only under load
    Mercer, Pa
    Hit valve with a plastic mallet and still leaks out the exhaust.
  1. Missfire at idle, shudder at 40mph low rpm load
    By Z28 in forum General Tech Discussion
    Last Post: 08-06-2014, 12:13 PM
  2. cylinder #2 missfire
    By Trett93 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2014, 02:58 PM
  3. 04 gtp cylinder #3 missfire
    By slgrnvlfire in forum General Grand Prix Discussion
    Last Post: 08-18-2013, 12:52 PM
  4. 01 every cylinder missfire.
    By jbb421 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 06:31 AM
  5. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
