Thread: squeal noise from engine when under load
Results 1 to 9 of 9
  1. #1 squeal noise from engine when under load
    Mar 2015
    Canads
    Hey, so I recently started to have an odd squel noise almost like letting the air out of a ballon. So I found metal in the super charger and replaced it and nothing. Seems as though when it squels the care has problems sucking in air. I am thinking maybe an intake gasket is letting air out or maybe even a wastegate? Some ideas to check would be great
  2. #2 Re: squeal noise from engine when under load
    Mar 2015
    Canads
    On idle and start up it is fine, even revving up to 4k while in park there is nothing but once you give it lots of gas and the super whine kicks in is when I hear that squel noise
  3. #3 Re: squeal noise from engine when under load
    Mar 2015
    Canads
    Forgot to mentiom 2000 grand Prix gtp
  4. #4 Re: squeal noise from engine when under load
    Kemmerer, Wyoming
    sounds like a vacuum leak. do you have a scan gauge that reads boost and/or long term fuel trims?
  5. #5 Re: squeal noise from engine when under load
    Mar 2015
    Canads
    The DIC isn't working but would a loud squel come from a bad vacuum. Even driving it is fine unless you are asking for some power. Like I said the second the super kicks in it has a lot of trouble. Another point to mention is before this happened I could hear large amounts of air rushing into the intake, now when I give it power it almost sounds like air is pulsing in and out of the intake
  6. #6 Re: squeal noise from engine when under load
    Kemmerer, Wyoming
    still sounds like my previous diagnoses
  7. #7 Re: squeal noise from engine when under load
    Mar 2015
    Canads
    Ok I will have to take a look, thanks for the help I will get back to you if this was the solution but other comments will be greatly appreciated
  8. #8 Re: squeal noise from engine when under load
    Donating Users Uno99's Avatar
    Appleton, Wi
    Mine does something like this even after my rebuild. Mine is more like a high whistlejust for like 2 sec after cold startup. Pretty sure its my iac
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  9. #9 Re: squeal noise from engine when under load
    Mar 2015
    Canads
    Well the cold start with a whistle I believe would just be the supercharger. Mine squeals whenever its a cold start up. Do you lose power and such to? We have it down to 3 options, vacuum leak, head gasket leak or intake leak. ripping it apart this weekend to see what's up
  1. Engine tapping noise under load and cold only
    By mojonba in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 09:07 PM
  2. Engine squeal, vacuum related *UPDATE* Problem Solved (see last post)
    By 98L36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2011, 03:21 PM
  3. clicking noise during load
    By pur3vil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2011, 07:43 PM
  4. having troubles with load on engine
    By tonydtech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2009, 03:44 PM
  5. engine can't handle load...
    Last Post: 05-02-2009, 02:51 PM
