Thread: top swapped and now a problem
Results 1 to 20 of 26
  1. #1 top swapped and now a problem
    Jul 2014
    New Jersey
    So i just top swapped my gt, when i try to turn the car on it sounds like im full of misfires and the engine bay fills with white smoke (hopefully from an exhaust leak which i have (i hate you obx headers))
    My thoughts are i ****ed up the ignition wires somehow or the injectors are clogged since i got them from the jy
    And i dont know the signs and dont want to even look it up but maybe head gasket issue
  2. #2 Re: top swapped and now a problem
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Front 3 from left to right: 1 3 5
    Rear 3 from left to right: 2 4 6
    Match them up to the cylinders numbered on the coil packs.
    You did write the 36# injector table into the pcm, right?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  3. #3 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    I sent it to zzp so god knows what they did
  4. #4 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    But i told them i had gtp injectors
  5. #5 Re: top swapped and now a problem
    Cibolo, TX
    Ok we'll assume your injector table is g2g then. How about those plug wires?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  6. #6 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    I was faily confident in them but i have to wait for tomorrow to double check
  7. #7 Re: top swapped and now a problem
    GTP Level Member
    Jan 2015
    Lincoln, NE
    check the compression on the motor. did you have the heads planed so they were flat? type of headgaskets? white smoke is usually coolant...
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  8. #8 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    I didnt have them machined but went over them with some feeler gauges and a straight edge and they were perfect
  9. #9 Re: top swapped and now a problem
    Cibolo, TX
    The car hasn't been started yet right, just cranked?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  10. #10 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    That would be correct
  11. #11 Re: top swapped and now a problem
    Cibolo, TX
    Let's get it idling before anything if we can. Does your tach move while you're cranking it?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    I didnt even think about looking at that, I'll let tomorrow afternoon when i get back to it
  13. #13 Re: top swapped and now a problem
    Cibolo, TX
    If not, double check your ICM and make sure your crank sensor is plugged in. ICM ground, too, sometimes that gets overlooked. And double check plug wires, make sure those are good. If you can toss a couple engine bay pics in we might see something out of place by chance, couldn't hurt.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  14. #14 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Okay i will, i appreciate all the help, I'll make sure to check this stuff out
  15. #15 Re: top swapped and now a problem
    your in south Jersey aren't ya??
  16. #16 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Yeah I'm in Gloucester County
  17. #17 Re: top swapped and now a problem
    your a ways off from me.
    turn the key to run and check for gas leaks and then check for fuel pressure too.
  18. #18 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Okay I'll add that to my ever growing list haha
  19. #19 Re: top swapped and now a problem
    Jul 2014
    New Jersey
    Thanks btw
  20. #20 Re: top swapped and now a problem
    whats it doing when you crank it? popping and back firing out the tb?
  1. 98 GP GT L67 swapped needs pcm which one??
    By 98PONTIAC in forum General Tech Discussion
    Last Post: 12-27-2012, 03:14 PM
  2. Top swapped
    By Dragon1972 in forum PCM Tuning
    Last Post: 05-03-2012, 09:07 AM
  3. Top swapped L26 goes BOOM :D
    By nitroheadz28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2012, 08:05 PM
  4. Swapped 05 L32 into an 04 L26 HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 04-20-2011, 07:32 PM
  5. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
