Exaggeration, but not sure what happened yet. Its a top swapped L26 with a 3.4 pulley/ 42.5lb injectors/ TOGS+ full exhaust/ ZZP fuel rail and pcm.
I was pulling out of taco bell after getting some food, I floored it to get up to speed. When I got to around 4k in 2nd gear, the car bogged and I let off immediately. (First time its ever done that).
I get to the light to come back to school, and its running on the rough side- nothing too crazy. The boost started fluttering up to 3-5psi at idle. I limped it back to campus and now theres a metallic clinking coming from the top end, it sounds like the screws in the M90 ran dry of oil and are just clunking together.
I had a buddy come help me diagnose it, as soon as he touched my engine- the SES light came on LOL.
I guess now I'm just hoping I can make it the 40 miles back home without it exploding, and looking for supercharger oil. If its not a lube issue, I guess its onto another charger. I don't know what gens can bolt on to which engine, so maybe theres a write up on that.
Is there anything else I might be overlooking from the symptoms I'm describing to you guys? Its definitely not knocking, it doesn't sound like a valvetrain issue either.
