Thread: Small miss or stutter at wot
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 80
  1. #1 Small miss or stutter at wot
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    98 gtp, Just put 3.4 pulley on zzp pcm 180t stat 605 plugs supercharger gasket cold air intake, down pipe no cat u delete, sometimes when at wot it kinda sputters or a slight miss this doesn't happen all the time, in stumped..
  2. #2 Re: Small miss or stutter at wot
    GrandPrix Junkie
    St. Louis
    Do you have any KR? Does the CEL flash when it stumbles?
  3. #3 Re: Small miss or stutter at wot
    Antioch, IL
    get headers problem solved, or a new engine soon either works
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Small miss or stutter at wot
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Did you list supercharger gasket as a mod? What are your plugs gapped to?
  5. #5 Re: Small miss or stutter at wot
    Topeka, ks
    Nothing flashes when stumbles
  6. #6 Re: Small miss or stutter at wot
    Topeka, ks
    Could this be my sc belt slipping at high rpm
  7. #7 Re: Small miss or stutter at wot
    get some 104 copper plugs gaped at 0.50 in there.
    how much kr your seeing? not scanning? you had best start. if you got a droid phone look up the torque app.
  8. #8 Re: Small miss or stutter at wot
    Topeka, ks
    Not scanning I can scan with my phone?? Do I just need the obd2 blue tooth for my car??
  9. #9 Re: Small miss or stutter at wot
    Topeka, ks
    605 plugs gapped at 55
  10. #10 Re: Small miss or stutter at wot
    http://www.grandprixforums.net/threa...ive-KR-monitor tells all about it.
    it reads the same data as my dhp scans. so its very accurate.
  11. #11 Re: Small miss or stutter at wot
    Quote Originally Posted by xxburkettxx07 View Post
    i had them plugs for like 20 miles. went to 104's felt much better. they are just in a box here, i should sell em. lol
  12. #12 Re: Small miss or stutter at wot
    Cibolo, TX
    Look at your SC snout, by the pulley. If you see a bunch of black stuff around there, good chance your belt is slipping. If you're using the stock size belt with a 3.4, I can just about guarantee it's slipping. Which may actually be helping you, belt slip = less boost = less KR. 605's is what I run in my GT, I wouldn't use them with anything smaller than a stock pulley, but that's just me. You also want as wide of a gap as you can run w/out spark blowout, this will vary so you have to play with it a bit. .055 is a good place to start, if you need to go lower do it, but .045 is like nitrous small.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  13. #13 Re: Small miss or stutter at wot
    Topeka, ks
    If it is slipping would it feel like a miss, should o.I run 104 plugs
  14. #14 Re: Small miss or stutter at wot
    Cibolo, TX
    Do the bars on your boost guage fluctuate at all? Or I guess with a 3.4 they might be maxed all the time, you should get that scanner and get some scans in before doing anything else tbh.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  15. #15 Re: Small miss or stutter at wot
    Topeka, ks
    I ordered the blue tooth scan thing n app n no the boost gauge don't move it's maxed
  16. #16 Re: Small miss or stutter at wot
    Cibolo, TX
    What about black stuff all around the blower pulley/snout? Anything there? If I use the same belt with my 3.2 that I do with my 3.5, it slips and I can see that crap start to form around there. Did you put a smaller belt when you dropped pullies?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  17. #17 Re: Small miss or stutter at wot
    Topeka, ks
    660 the belt I put on
  18. #18 Re: Small miss or stutter at wot
    Antioch, IL
    Quote Originally Posted by 99GT2dr View Post
    100% false, ran stock on 3.4 with 120% zero issues, as do many others
  19. #19 Re: Small miss or stutter at wot
    Quote Originally Posted by ITHURTZ View Post
    me too, stock belt 3.4 pulley, no slip at all.
  20. #20 Re: Small miss or stutter at wot
    Topeka, ks
    I can't run 103 plugs? I have 103 already and the 605s And 606s all bought with in 8 months 104s a must? I'll get if so
  1. stutter start?
    By grandprix85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 02:10 PM
  2. Stutter when cold
    By gpse2000 in forum General Tech Discussion
    Last Post: 09-19-2011, 08:15 PM
  3. 05 GTP Comp G Engine Stutter
    By mrnodaysoff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2011, 08:22 AM
  4. Stutter/jerking going up hills or small inclines
    By robert3112 in forum General Tech Discussion
    Last Post: 12-29-2010, 02:38 PM
  5. 2000 SE 3.1L engine stutter
    By ejstark in forum General Tech Discussion
    Last Post: 06-30-2009, 01:03 PM
