Thread: M90 Bypass Engagement Switch
Results 1 to 4 of 4
  1. #1 M90 Bypass Engagement Switch
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Hey all,
    Preface this by saying, there is no practical/logical reason to do this, just thinking it would be a cool gimmick....
    Say you have a switch wired in series with the PCM control of the boost bypass solenoid. (A big red button on your center console or dash, etc.)
    You go WOT, and the S/C stays in bypass (building less boost obviously), then you press the button (bypass closes), and it gives you an extra slap of speed.
    Seems like the wiring would be very simple, and wiring it in series with the PCM means that you won't activate it under conditions where the PCM would consider it unsafe to do so.... thoughts? Could be a cute little project. I was thinking about tying the performance shift pins into the same button, kind of like a "performance mode" that changes several characteristics in one go.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: M90 Bypass Engagement Switch
    Jul 2012
    Chicago
    Seems like this would make the input shaft cry even more.
    -Carl
  3. #3 Re: M90 Bypass Engagement Switch
    May 2012
    Where winter never ends
    https://www.youtube.com/watch?v=qeaZgX_N7r8
    Much more useful, something me and Frosty made.
    2000 Regal - Winter Beater
  4. #4 Re: M90 Bypass Engagement Switch
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Show us on the doll where your transmission touched you. Talking about it might make you reconsider your plan to kill it.
  1. can i bypass the ignition switch to get heat
    By stanwich in forum How To Write-Ups/Tech Tips
    Last Post: 12-10-2013, 11:05 AM
  2. Supercharger bypass solenoid and bypass actuator question
    By 2004blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2013, 04:46 PM
  3. DOD engagement
    By GeeXPee in forum General Tech Discussion
    Last Post: 05-07-2011, 11:21 AM
  4. False ABS engagement...no abs light
    By eman84 in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2010, 06:17 PM
  5. Torque Converter engagement
    By 98SilvermistGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2008, 03:49 PM
