Update-
Found out my brother can't weld aluminum because he does not have the correct liner for the softer aluminum wire,Said the aluminum wire since it is softer tends to get kinked up. He said Ideally you're suppose to have a spool gun wich he also does not have. Other than those two things being missing he would have no problem doing it.
So it looks like I may just have to find someone else to weld them or else go the epoxy route.
BTW Scotty that brass thing is called a ''welder's helper''
