Thread: Car won't start once again
Results 1 to 4 of 4
  1. #1 Car won't start once again
    GT Level Member blownGP's Avatar
    Sep 2013
    Iowa
    OK I've got another problem. 2 days ago I noticed my car was cutting out on me during acceleration. I didn't have time to look into it and kept driving. Then yesterday it struggled to even get me home. Today it quit twice pulling out of the driveway so I just drove something else and now I get home with time to look at it and it won't start at all. It says full boost all the time even when it's off. It goes from saying a single cyl misfire to multiple cylinder misfire so it's not just cylinder 3 it's all of them at one point or another. Any help would be greatly appreciated!
    2000 2500 Chevy with 6 inch lift build thread- http://www.gmt400.com/forum/showthre...d-Crew-Cab-454 2006 Grand Prix supercharged build thread- http://www.grandprixforums.net/blown...ead-82585.html
  2. #2 Re: Car won't start once again
    http://engine-codes.com/p0641_pontiac.html not a good code. if you have a open cone filter and the pcm laying there look for a rubbed wire to the pcm. or any other rubbed wires.
    make sure the battery and grounds are all tight and clean too.
  3. #3 Re: Car won't start once again
    Dec 2012
    Where 4T65E's were born
    After that, pull a connector on one of the 5 volt sensors and test the v-ref wire. Should see 5 volts. If not as he said check all the wiring. Then start pulling all the connectors for the other 5 volt sensors and see if it comes back after pulling a connector as one of the sensors could be shorted. Worst case the pcm's 5 volt control has failed.
    Sold.
  4. #4 Re: Car won't start once again
    Sep 2013
    Iowa
    Another set of plugs and wires and it's fixed
  1. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  2. Installing remote start on non-remote start car
    By GPmanter in forum General Grand Prix Discussion
    Last Post: 01-29-2016, 11:39 AM
  3. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  4. how to>new fob for auto start, already have auto-start installed
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 12-20-2014, 06:53 AM
  5. no start
    By Snoop dogg in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-08-2014, 10:14 AM
