Thread: Top Swap having horrible idle, no power on throttle
Results 1 to 20 of 67
  1. #1 Re: Top Swap having horrible idle, no power on throttle
    use what ever bolts you got that will fit.
    and the tb vac line, thats routed to the right place. i guess you used the old line off the n/a tb. if that fat hose there is leaking not tight, cracked, it can cause that surging, and could be whats leaking when you spray the tb area.
    you can get a new fat line, like 3 inches long, then take the new vac line from the evap solenoid., and push it inside the fat line.
    this is how i fixed my fat line when it cracked on me. fat hose to normal vac line to the hard line. on a sc car, the evap lives on the rear of the engine on that bracket you posted a few weeks back.
  2. #2 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    The rpms only go up when I spray right where the TB meets the SC. I replaced the gasket with the brand new one and it still did it. I'm kind of thinking that it just soaks into the gasket and then gets in there? I mean, it's a brand new gasket, and torqued down to specs and then some. I could go all around the gasket with some Blue RTV i have if you think that's neccesary. Also, I used MAF cleaner instead of Carb cleaner. I didn't have any carb cleaner so I figured MAF would be okay to use since it's less aggressive. My EVAP is still at the front of the car, same place it was at before the swap.
  3. #3 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    also here is the new youtube vid. took a while to upload. Thanks for all the help guys, I really appreciate it.
    https://www.youtube.com/watch?v=JfS7...ature=youtu.be
  1. Throttle CEL(s) No Power
    By Crocitto49 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-22-2013, 11:26 PM
  2. 2000 GT stall at idle and when let off throttle
    By burgundybullet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2013, 09:28 PM
  3. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
  4. warm/hot start HIGH rev idle/ sticking throttle??
    By rschap1 in forum General Tech Discussion
    Last Post: 04-03-2012, 01:26 PM
  5. Throttle bounces at idle AND while driving
    By navillus in forum General Tech Discussion
    Last Post: 05-30-2010, 04:48 PM
