Thread: Is my fuel line routing correct? Just top-swapped.
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Is my fuel line routing correct? Just top-swapped.
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    The only thing the bbv solenoid does is allow the pcm to control boost for traction control. With it vented to atmosphere, the pcm will have no control over the boost, but it will still allow normal operation of the bbv (foot in throttle, it closes, and bewst!).
    All i did was remove the solenoid, leave the line connected to it from the blower open, and remove the vac line going from solenoid to fpr (instead of a tee on the fpr, swap with an elbow to run to lim).
  2. #22 Re: Is my fuel line routing correct? Just top-swapped.
    Nov 2014
    Minneapolis, Minnesota
    Once, my swap gets a little closer I think this will make a lit more sense, but I think I get what you are saying.
    Thanks 99GT2dr.
  3. #23 Re: Is my fuel line routing correct? Just top-swapped.
    Nov 2014
    Thanks 99GT2dr.
  4. #24 Re: Is my fuel line routing correct? Just top-swapped.
    Nov 2014
    Whoops! Crazy phone here..
  5. #25 Re: Is my fuel line routing correct? Just top-swapped.
    Cibolo, TX
    http://www.fiero.nl/forum/Forum2/HTML/127224.html
    Pics and plenty of info in that thread, check it out.
  6. #26 Re: Is my fuel line routing correct? Just top-swapped.
    Nov 2014
    Thanks 99GT2dr, that thread was right on the money!
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. Power steering line routing
    By huttler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2013, 05:39 PM
  3. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  4. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  5. looking for a vacuum line routing guide
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2010, 12:02 PM
