Thread: largest l67 intercooler
Results 1 to 12 of 12
  1. #1 largest l67 intercooler
    Sep 2013
    Massachusetts north shore
    Whats the largest l67 intercooler i can fit under a 2001 gtp i have a ssic with a 3/4 spacer if i remove the ssic can i fit a zzp core with the 3/4 phenolic spacer and would a gen v fit in the future
  2. #2 Re: largest l67 intercooler
    hangover park IL
    if i jack up my 97 gtp i guess i could fit a 25" tall stack of intercooler cores under it
    your limited at about 2.25" without weaseling with a buncha mounts and cradle spacers. so a full size IC and maybe a 1/4" spacer (im assuming you have a 3/4" phenolic)
    no difference in the stack eight of a gen3 vs gen5
    ~James~ Psychotic Gearhead
  3. #3 Re: largest l67 intercooler
    Sep 2013
    I have heard that a gen v is taller at the t.b. but i dont know if it will fit
  4. #4 Re: largest l67 intercooler
    That's why they make a turn down adapter for the GenV. It is a longer blower.
  5. #5 Re: largest l67 intercooler
    isn't the turn down really only needed if your running a N* TB? thats pretty much the only pics ive seen of them being used.
  6. #6 Re: largest l67 intercooler
    Nov 2012
    Erlanger, KY
    I ran the zzp 2.25" IC, GENV + adapter + N*.. no turn down. With my GTX hood. Fit fine with no spacers.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  7. #7 Re: largest l67 intercooler
    May 2008
    Schuyler, NE
    The turndown was made for 04+ cars.
  8. #8 Re: largest l67 intercooler
    Made for the 04+ guys that run IC since our throttle bodies are taller and once you throw a IC in there the TB tends to hit. Previous gen can just get a adapter and turn the tb upside down to make room.
    04 Comp G.
  9. #9 largest l67 intercooler
    Mercer, Pa
    I'm running my 2.25" intercooler. I've bolted up L67 and N* under a 2002 and 2003 bonneville hood.
    It's a tight fit! Not sure I've heard of anyone running thicker than 2.25 without doing cradle spacers, notching the hood or both on any vehicle.
  10. #10 Re: largest l67 intercooler
    Mercer, Pa
    I found your intercooler. It's not very descriptive.
  11. #11 Re: largest l67 intercooler
    Sep 2013
    Its not descriptive at all but i talked to the seller and by the pics of the engine its a zzp wbody store i/c i wanted to try and keep the phenolic spacer but its not worth the hassle i dont really want to deal with the pcv system i have been looking for a clean setup and install i might just sell the ssic, spacer, and full size and get the hybrid by the way the same seller has other 3800 performance parts
  12. #12 Re: largest l67 intercooler
    Mercer, Pa
    I posted his Australian RWD m90 L67 on the forum. Not many in the states.
  1. Intercooler and more
    By Hawkman in forum For Sale - Parts
    Last Post: 11-15-2013, 12:28 PM
  2. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  3. Largest available rear swaybar?
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2009, 10:02 PM
  4. Oklahomas Largest meet(vid)
    By Toofastgs in forum Shows and Events
    Last Post: 11-02-2008, 07:10 PM
  5. Largest Grand Prix Club
    By Rocket468 in forum Off Topic Discussion
    Last Post: 01-03-2008, 08:48 AM
