Yea......That's right. I'm still searching for more though, Andes........
I'm at work and trying to be sneaky....Lol. rushing to post and made a mistake.
Anyways, to the experts....Lol. all the info and help we can get on this will be greatly appreciated.
Just do it. Quit sweating the small stuff... Once you start it's like Legos , just greasy oily Legos....
S1x is a great cam. You will be very happy
no one ever did a cam install and said they would rather have the stock cam instead![]()
Just have all your gaskets and prep materials ready
good time to clean and paint everything as well
Regasket everything and take your time.
As long as the motor has been taken care of, 200k~ ain't sh1t.
Be sure to go have the front cover cleaned out for any sort of build-up, I'd honestly get an '04+ spring kit for the oil filter housing too...helps bump oil pressure a bit...along with a new oil pump gear if you have the extra money lying around.
I'll will keep that in mind, Blue
I have all the gaskets for a LIM gaskets replacement. What other parts and gaskets would I need to do a s1x cam install?
Besides 04+ spring kit and oil pump gear.
Springs ? New lifters ?
I prefer 105s with a new stock chain and dampener
you can do stock lifters
I chose to ditch the oil restricted rods I used when I had 1.9s and go with the oe-r lifters
Besides springs , its all preference but either way I'd replace everything while there with something new
I guess I'll get some rockers also.
Why?
I don't know....I just found out it wouldn't do any good. So, i'll forget that idea.
Plus, I don't have any custom head work done for anything more than 1.6
