Wanted to give yall a quick update. Pulled the fuel pump after replacing a series of parts isolating the issue(Evap system components not functioning, specifically the purge solenoid has no signal what so ever). Metal shavings in the gas tank and in the fuel pump filter. Talked to a buddy of mine, he as seen this when fuel pumps go bad. It is possible the failing fuel pump is pushing too much fuel into the motor, thus the -20% Fuel Trims.
Got another pump on the way, hopefully this resolves the issue. This is becoming a chore.
