BTW..did you spot the correct nut for the tensioner yet?
I just used the 15mm and grinded down a socket, worked like a charm. Thanks tho
Got her a new battery. She tries really hard to start but no luck. The Fuel pump doesnt choke anymore with the new battery in. I can still hear the pump Priming itself when i turn the key. Dont know if I need to change wires, plugs? I checked fuses they seem to be correct and working. Will try again tomorrow. Thanks
