Thread: Hood wont close with intercooler
Results 1 to 20 of 32
  1. #1 Hood wont close with intercooler
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    When i put the intercooler on it made the supercharger sit too high and it hits my hood, Its about and 1.5 inches too much, and i have an sd hood
  2. #2 Re: Hood wont close with intercooler
    cradle spacers, they lower the sub frame. but 1.5 inches is a lot.
  3. #3 Re: Hood wont close with intercooler
    Mar 2012
    NC
    ^^^This.
  4. #4 Re: Hood wont close with intercooler
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Yup,and the SD hood has less clearance than a stock hood.
  5. #5 Re: Hood wont close with intercooler
    Mar 2012
    NC
    Quote Originally Posted by 231FUN View Post
    ^^^And this.
  6. #6 Re: Hood wont close with intercooler
    Kemmerer, Wyoming
    put some spacers inbetween the hood and where the hood bolts on, it will give you a bit more clearance, might be enough after you do the cradle spacers
  7. #7 Re: Hood wont close with intercooler
    Kemmerer, Wyoming
    I ended up putting a stock hood on. then I cut a hole and put a scoop on.
    Hood wont close with intercooler Attached Images
  8. #8 Re: Hood wont close with intercooler
    reason #5876769303064897839023035 why I think A2W intercoolers are a joke..........
  9. #9 Re: Hood wont close with intercooler
    Mar 2012
    NC
    mine fit under a stock hood no problem....
  10. #10 Re: Hood wont close with intercooler
    Jun 2013
    brookville,IN
    Ill see if i cant get it with the spacer but i really doubt it.
  11. #11 Re: Hood wont close with intercooler
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    Quote Originally Posted by 98FawkedUpNaviVet View Post
    for me the is reason #1, I know I wont have enough space so I wont even bother lol
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  12. #12 Hood wont close with intercooler
    Mercer, Pa
    There are intercoolers on lots of cars. Before you bye, look up your car/hood. Chances are some one has installed on and has some pictures. If cannt find info.
    1). Remove hood insulation (been asked if it was really nexessary)
    2) put plummers putty on vacuum nipple on top of supercharger.
    3) gently lower and or shut the hood.
    4) putty will show how much clearance you really have.
    As far as a joke....I drive mine daily for the last 6 years.
  13. #13 Re: Hood wont close with intercooler
    And once again e85 isn't easily available everywhere....
    04 Comp G.
  14. #14 Re: Hood wont close with intercooler
    Jun 2013
    brookville,IN
    havent found any info about it yet hopefully something turns up i dont wana cut this hood
  15. #15 Re: Hood wont close with intercooler
    Run hoodless
    04 Comp G.
  16. #16 Re: Hood wont close with intercooler
    Mercer, Pa
    1-1/2. Is that at the front of the car?
    What car and hood
  17. #17 Re: Hood wont close with intercooler
    Jun 2013
    brookville,IN
    Yes the front of the hood its an SD hood on a 2000
  18. #18 Re: Hood wont close with intercooler
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    Trade you my stock hood before you cut up the SD hood.
    Official GPF Red Neck
  19. #19 Re: Hood wont close with intercooler
    Jun 2013
    brookville,IN
    no thx
  20. #20 Re: Hood wont close with intercooler
    Feb 2013
    Ohio
    Okay...then just chop up the SD....make it completely useless......it will crack and break...then you will be looking for a stock hood in the end anyway. Its only money......what the hell!!
  1. sunroof wont close completely
    By johnfolks in forum Visual/Body Modifications
    Last Post: 07-24-2013, 11:40 PM
  2. help sunroof wont close
    By red97gtpcoupe in forum General Tech Discussion
    Last Post: 09-26-2012, 05:15 PM
  3. Intercooler clearance issue! Cut the hood or take out spacers?
    By copgtp in forum General Tech Discussion
    Last Post: 07-23-2012, 09:28 AM
  4. Hood clearance w/ZZP stg 2 intercooler
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2010, 11:57 PM
  5. will ws6 hood fit over intercooler
    By 01gtpjk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 01:19 PM
