Thread: Car dies upon starting
Results 1 to 13 of 13
  1. #1 Car dies upon starting
    Nov 2014
    IN
    So I bought a 2004 Grand Prix GTP Comp G a month ago and every time I start it, it dies. But when I start it, I can give it a little rev and it will run just fine. Anyone know why it does that? Right now, it's in the shop getting the tranny replaced but it was replaced 3 days prior to me buying but the tranny slipped and kicked out of gear every time I drove it. But can anyone help with the starting issue?
  2. #2 Re: Car dies upon starting
    dirty TB can cause this. the check engine light on? if so get it scanned and post the code.
  3. #3 Re: Car dies upon starting
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I agree with Scotty, sounds like a dirty throttle body. Had the same problem with the 06 I'm daily driving when I purchased it.
  4. #4 Re: Car dies upon starting
    Nov 2014
    IN
    I have no engine lights on. No lights at all. I'm usually mechanically inclined but I've never had a car do this before
  5. #5 Re: Car dies upon starting
    its simple to clean, take it off, spray the back side where all the carbon is with carb cleaner and wipe off with a rag. clean the flap the sides of the flap and the walls till they all shine.
  6. #6 Re: Car dies upon starting
    Nov 2014
    IN
    I'll be sure to do that when I get my car back! Thanks a bunch!!
  7. #7 Re: Car dies upon starting
    call that trans shop and have them install a shift kit while they are back in there. they make the trans last longer if your beating the snot out of it.
    faster firmer shifts = less clutch wear. where stock those soft mushy shifts are burning the clutches.
    you can get a shift kit for like 40 bucks on e bay. its easy to install if the shop cant get one.
  8. #8 Re: Car dies upon starting
    Nov 2014
    IN
    The tranny was under warranty so everything is being done free. Do you have link on how to install a shift kit? Because they are just replacing the tranny. Do I have to pull the tranny apart to install one or what?
  9. #9 Re: Car dies upon starting
    all you have to do is drop the pan. being its a new tranny, id get a real clean catch can and reuse the fluid to save 40 bucks right there.
    heres a how too. http://www.grandprixforums.net/threa...ailed-Pictures
  10. #10 Re: Car dies upon starting
    Nov 2014
    IN
    Sweet. Thanks!
  11. #11 Re: Car dies upon starting
    May 2013
    Wheelwright
    Mine done that same thing one day when a plug came loose near where the battery sits.
  12. #12 Re: Car dies upon starting
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    You should download Torque Pro
    If you Have android device. It's a great scanning app
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  13. #13 Re: Car dies upon starting
    Nov 2014
    IN
    So I just called the shop today to see about when I'll have my car back. they have had it for a week and they told me they can not find a transmission for it. The previous owner had a mechanic do the replacement so they can't just rebuild the one that's in it. I'm getting so mad!
  1. 04 gt just dies after starting
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 09-13-2014, 11:00 PM
  2. 00 GTP struggles to run after starting,dies after a few seconds.
    By iowagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2014, 01:31 PM
  3. Car dies when starting in cold weather?
    By 2007GPGTSC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2014, 02:17 PM
  4. PO128 code/Engine dies after starting/Related?
    By quickster in forum General Tech Discussion
    Last Post: 12-29-2011, 06:13 PM
  5. car dies if I take oil cap off
    By Corona99GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2011, 11:25 AM
