Thread: seafoam
Results 1 to 13 of 13
  1. #1 seafoam
    Vail, CO
    when going to run seafoam through the intake, should i do it through the brake booster line? or the middle vacuum line on top of the supercharger?
    car is a 98 gtp
  2. #2 Re: seafoam
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    brake booster. About 1/3 of a can. Shut it off for about 15-20 mins then run it til the white smoke is gone. DO NOT put it in your oil.
  3. #3 Re: seafoam
    Vail, CO
    what will putting it in the crank case do?
  4. #4 Re: seafoam
    SWPA
    Thin the oil and possibly cause a spun bearing.
  5. #5 Re: seafoam
    Jul 2012
    Chicago
    Apparently putting it in the oil is fine if you plan on doing an oil change soon after. Like think 50 miles soon.
    -Carl
  6. #6 Re: seafoam
    Vail, CO
    got it, thanks
    gonna avoid putting it in the oil, ive had bad luck with this car and dont wanna tempt fate
  7. #7 Re: seafoam
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I've always done half through the brake booster line and the other half in the fuel tank.
    Would never pour it in the crankcase for any length of time.
  8. #8 Re: seafoam
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I am going to try this weekend
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  9. #9 Re: seafoam
    SE Level Member kkehlet's Avatar
    Aug 2014
    Midwest
    you may want to run a bottle of marvel's mystery oil in the crank case
  10. #10 Re: seafoam
    Antioch, IL
    1 can in vac line, 1 can in gas tank, never the oil
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: seafoam
    gardner,mass
    Quote Originally Posted by ITHURTZ View Post
    ^this
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  12. #12 Re: seafoam
    Vail, CO
    if my wires, plugs, and oil are all relatively new when i do the intake cleaning, should i still change them after?
  13. #13 Re: seafoam
    your plugs will live. but its always nice to seafoam and then do a full tune up when needed. your plugs are burning off a lot crap, why its smoking so much out the tail pipes.
  1. Seafoam my 00 gt and 01 gt
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 08-25-2014, 06:25 AM
  2. Seafoam
    By traildog in forum General Tech Discussion
    Last Post: 02-07-2014, 08:36 PM
  3. How to use seafoam?
    By patrickgrandprix in forum Introductions/Noob Questions
    Last Post: 04-30-2013, 03:00 PM
  4. how to seafoam a 97 gtp?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2012, 08:36 PM
  5. Seafoam
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2012, 07:39 AM
