Thread: Map sensor bracket
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Map sensor bracket
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    They are black in the 00 also
  2. #22 Re: Map sensor bracket
    Jul 2010
  3. #23 Re: Map sensor bracket
    Jul 2010
    That last one is out of the 00,both same
  4. #24 Re: Map sensor bracket
    Yeah..wrong bolt
  5. #25 Re: Map sensor bracket
    Jul 2010
    In both cars?,it went in and out good in my 00,they are black all around sc on both,only silver are pcv,then the tree,the other stuff I took off was alternator which was studd,and nuts,the bigger bracket in the back that holds the 02 sensor wire which was nuts and that's it,them was the only 2 lol,they were sitting flush like they were supposed to and the bracket wasn't floppy or moving around any,I guess there's only one thing to do if I don't want washers,trim them a little,that's the only thing I can think of
  6. #26 Re: Map sensor bracket
    Jul 2010
    I even tried a little high temp grease
  1. EVAP Switch, MAP Sensor Bracket. 97 GTP
    By slydoggy38 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2013, 09:01 PM
  2. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
