Thread: Map sensor bracket
Results 1 to 20 of 26
  1. #1 Map sensor bracket
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    I'm currently working on my valve cover gaskets and the 2 bolts that hold the bracket on will not go back in their holes,trying them with washers but has anybody had this problem???
  2. #2 Re: Map sensor bracket
    hangover park IL
    the bolts your tossing in are too long. you mixed them up with other hardware somehow. ive seen plenty of divots in the LIM's and top face of IC's from it.
    the holes are through threaded and near the blower mounting boltholes, but are made blind by the lim/ic when the blower is bolted to the engine.
    ~James~ Psychotic Gearhead
  3. #3 Re: Map sensor bracket
    Jul 2010
    Its the only 2 like that,was very hard to get out to
  4. #4 Re: Map sensor bracket
    Jul 2010
    On the 00 gtp I couldn't even get one out to compare
  5. #5 Re: Map sensor bracket
    Jul 2010
    They go in mostly then get very snug,so instead of tightening to tight and cracking anything I put 2 washers on each screw and the bracket is tight,you think this way will be ok,seems like if they come out they'd go back in
  6. #6 Re: Map sensor bracket
    hangover park IL
    did anyone replace them with SAE hardware? the bolts should be m8x1.25 thread
  7. #7 Re: Map sensor bracket
    Jul 2010
    Looks like the rear cover was changed before,it was diffent than the front,the screws are the same ones that are on the blower or around it,I found on Google that it takes 22 ft lbs of torque,could that be why,maybe it requires a air ratchet??,my drill impact wouldn't budge them,pretty sure nobody has changed any screws,they start ok then just get tight
  8. #8 Re: Map sensor bracket
    Jul 2010
    I was just using a ratchet
  9. #9 Re: Map sensor bracket
    Like Turbo said.. I'd also think that you have the wrong bolts. They look just like SC bolts except they are shorter.
  10. #10 Re: Map sensor bracket
    Jul 2010
    I've got a little ocd and its driving me crazy lol,that was the only 2 bolts that went into the sc I took out,do you think that washer way or cutting the bolts down cause it has me stumped lol
  11. #11 Re: Map sensor bracket
    Picture please
  12. #12 Re: Map sensor bracket
    Jul 2010
    Of the bolts?
  13. #13 Re: Map sensor bracket
    Yeah..take a pic of how long one of them is..
    IIRC in some years they were silver instead of standard dark steel.
  14. #14 Re: Map sensor bracket
    Jul 2010
    These are dark and it will be awhile
  15. #15 Re: Map sensor bracket
    Jul 2010
    I'll take one out tomorrow, I had a long day
  16. #16 Re: Map sensor bracket
    I know the feeling.. If I have time..I'll try and see if I have pics.
  17. #17 Re: Map sensor bracket
    hangover park IL
    yeah the sc bolts are similar in design, but are about 5mm too long, never seen the map bolts in black, they are silver to differentiate em from the sc bolts, iirc they are the same length bolts as the vac tree/pcv cap on top of the blower
    someone mixed up bolts
  18. #18 Re: Map sensor bracket
    Jul 2010
    About to go get a pic
  19. #19 Re: Map sensor bracket
    Look for the silver bolts while you are there
  20. #20 Re: Map sensor bracket
    Jul 2010
  1. EVAP Switch, MAP Sensor Bracket. 97 GTP
    By slydoggy38 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2013, 09:01 PM
  2. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
