All right, multi-quote for all the cool kids, and I'll add some additional thoughts/hopefully to clarify the original post.
It's not so much "a cooler spot" than it is "a more accurate spot". Knowing the IAT right after it passes the air filter is completely useless in determining the actual intake temperature when it enters the engine.... because in a supercharged application there's this Eaton blower making heat in between the IAT sensor and the engine... While there is almost certainly a correlation between the two, it's not an exact science (at least not as exact as placing an IAT sensor in the LIM would be).
It's definitely a squirrel worth chasing, although it would be most effective if you combined it with a tune that automatically modified timing based on IAT, and allow you to eke out a few more ponies for as long as possible.
This sounds like what GM should have done with the L67 setup, but cheaped out (because L67's were produced in far greater numbers than their new SC'd V8s ever will be).
That's what Brian told me was the result of doing a 3rd gear pull on the dyno - it only started showing KR after a good fifteen seconds at WOT, and said "it was the blower outrunning the intercooler", I only had KR at ~5600 in 3rd (a speed that I honestly rarely reach).
I can't speak for Dan or what he's doing but I'm probably going E85 this winter/spring, basically as soon as I can scrounge up another $600 for 80# injectors, fuel pump, and the inevitable retune. Ported heads and roller rockers are also coming in 2015. Don't worry, I'll be stretching chains before long.
To clarify what I'm getting at in my original post, because I was really attempting to chase two squirrels at once:
1) The IAT's positioning is awful for a supercharged application. It's impossible to extrapolate exactly what the "true" IAT is after the blower, apart from "definitely a hell of a lot higher than before." That means from a tuning standpoint you're basically shooting in the dark and hoping you dial in the tune correctly. Moreover, it's impossible to accurately create an "adaptive" file that corrects for higher or lower IAT's - resulting in either (a) a chunked piston, or (b) a conservative tune that doesn't get the maximum number of ponies. The presence of an intercooler further complicates the IAT issue - we don't know how much exactly the air is being cooled, and moreover, a tune can't account for when the intercooler heat soaks and IAT's at the engine rise dramatically (even if they aren't per the IAT located near the air filter).
2) Irrespective of this terrible positioning, a CAI will lower IAT's, even post-blower, even if we don't know by how much. That should, in theory, permit more timing to be thrown at it, and thus add more power. I called out the "Dyno Science" thread because the car had the exact same tune for all pulls. He didn't retune for the CAI, however insigificant it may have been.
