So i was goingto swap out my pulley today, but i cant seem to be able yo remove this plastic pushpin that is covering the bolt. Does anyone know what I am talking about and how to remove it? Thanks.
I know exactly what you're talking about. I had trouble removing mine a couple months ago when i put on my MPS. I just eventually worked it out. I started using a flathead and eventually used a pair of garden shears. Yes i said garden shears. Once i could grab it with that I just cut off the tip and when the pulley came off the little bit left came off with it. That being said, a flathead and a pair of needle nose with a little WD-40 should work fine. Just be patient and stay with it.
warm up a phillips screwdriver with a lighter and shove it into the plastic piece and turn it out.
Once you get the edge of it up, you can also kinda unscrew it.Its not threaded itself,but the hole its in is.
