Thread: sputter when building boost.....too cold of a plug?
Results 1 to 3 of 3
  1. #1 sputter when building boost.....too cold of a plug?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Been a while since i posted to this forum!
    Mods: top swap, xp cam, 3.4 pulley, u-bend delete running autolite 104s gaped at .055"...98 gp
    She's been sitting for a while and i just got it back out to mess with it. anyhow, when building boost with a light throttle the car would sputter and would do the same from a light throttle to wot. So i decided to take a gander on the line and found similar situations and the guy closed the gap on his plugs..after reading the thread, i set the gap on my plugs to about .040" with roughly +.002" of an inch and -nothing. so at the most it was set to .042". The car ran a whole lot better...however the "sputter" was still there at wot! only thing i can think of is to cold of a plug maybe? thoughts/ suggestions are appreciated!! Thanks guys
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: sputter when building boost.....too cold of a plug?
    104's seem fine to me. .042 gap is kinda small, .050 sounds better to me anyway.
    I would just get 6 new plugs because they are so cheap.
    But could it be knocking aswell, you say only a u-ben delete with a cam and 3.4. That just doesnt sound like it would flow enough.
  3. #3 Re: sputter when building boost.....too cold of a plug?
    Jul 2011
    Michigan
    I've scanned with the setup and it wasn't knocking at all so I don't think that's the problems. I will try setting the plugs to .050 And see what happens. If that doesn't help I think I may try a different heat range to see if that fixes it....
    Would bad kr cause those symptoms? My 2008 has reached as much as 8 degrees with a stock motor and it didn't feel/ sound like that at all.
  1. 97 gtp l67 with Gen v m90 swap not building boost..
    By rob99gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2014, 03:10 PM
  2. Not building full boost
    By Wsmccoy in forum Turbo
    Last Post: 05-21-2012, 06:43 AM
  3. HELP! Sputter Under Boost (feels like missfire)
    By OrangeL67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2011, 12:07 AM
  4. Building Boost much faster
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 02:12 AM
  5. Building Cold Air
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:33 PM
