I'm just trying to lay down some boost here and the car is not letting me.
05' GTP had several problems most of which I have solved or am in the midst of solving. My scanner was supposed to be here a week ago so don't be too hard on me about it.
Basically I had a 3.4" pulley on the car when I bought it and recently changed to a 3.6" since I wasn't able to get a 3.8". The car has 2.5" from the manifold to the stock Y and a set of 2.5" 2 chamber flowmasters on it.
I added a air intake and new plugs and wires, original Platinum plugs then on advise I used AC copper 606's gapped at .050"
At this time I was able to get up to 10psi (before I changed pulleys), then all of a sudden this started happening.
I don't hear any detonation at all, I'm running 93-94 octane.
I added a boost gauge and a fuel pressure gauge. Fuel pressure is about 60-65 all the time regardless of engine load.
If I lay into the throttle from a stop the car comes alive until it reaches "0" then it seems to just go flat like there isn't any more power. The boost gauge will not go any higher.
If I roll onto the throttle from say 40 and slowly accelerate easing the needle into the boost area I can get it to 5 psi then it will hold there as long as I slowly apply throttle.
If I do the same and get to 5 psi then press a little harder the needle drops back to 0.
If I am rolling about 40 and press on the gas until I start getting into boost it will downshift and the gauge will drop to 0.
If I take it easy and start getting into boost 5psi is as high as it will allow.
My theory is that there is something that is causing the boost solenoid to kick in and bypassing it, or the throttle is limiting the intake of air to keep the car out of boost. Those are the only things that make any sort of sense to me. I am sure that the coupler drive to drive shaft has not failed and there isn't a way to limit boost any other way than having the bypass open and limiting the throttle opening.
I'm pulling my hair out over here.
Thanks,
Jeff
