Thread: 2004 L26 Grand Prix GT - Wild Cylinder Skewing from Factory (Discussion)
Results 1 to 4 of 4
Threaded View
  1. #1 2004 L26 Grand Prix GT - Wild Cylinder Skewing from Factory (Discussion)
    GT Level Member tylerbinski's Avatar
    Canada
    So after some head scratching, digging and research I have determined that in 2004, 2005 GM skewed the NA vehicles with the following.
    This only applies to Naturally Aspirated L26 equipped Grand Prixs.
    I am searching for the reason behind this. My only guess is that they determined the volume of air to be different per cylinder and adjusted the fueling to match.
    EDIT: Yes, Bio - good point, The rear manifold does infact flows better than front.
    ** would this mean more fuel required in the front to combat KR or less fuel since less flow ?
    ( i would guess more fuel)
    Can we get a discussion going here?
    I have never seen individual cylinder skewing from STOCK before.
    I have confirmed with multiple 2004 and one 2005 GP stock bin files.
    http://www.grandprixforums.net/lf-st...tml#post739989
    When I got turbo, I will be definitely setting them all to 100% and then making adjustments based on plug readings and whatnot.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  1. Cylinder #3 misfire on 1999 Grand Prix GT
    By protoplayer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2011, 09:11 PM
  2. Grand Prix GTP 3.8L V6 Supercharged Random Misfire Cylinder 3 PLEASE HELP
    By gtpmaddi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2011, 10:18 AM
  3. Master Cylinder replace 97 Grand Prix GT
    By Paul Salmon in forum Brakes/Suspension/Chassis
    Last Post: 08-14-2010, 08:22 AM
  4. 98 grand prix rear head cylinder swap
    By shihiran in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2010, 12:10 PM
  5. 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    By srlash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 10:00 PM
